Dean's update from Phoenix
tooquicktostop
Well took a drive down to Phoenix to pay some money and take a look at progress, its been a while since I saw the car last and things have moved on quite a bit, I have taken some quick pictures for you all to have a taster of what is to come :)
Fuel system is in now, this includes new twin Walbro fuel pumps, new braided lines from pumps to Ross racing fuel rail, aeromotive in line fuel filter and new 880cc injectors with all new injector cables and fittings
http://img2.putfile.com/thumb/5/13011190091.jpg
http://img2.putfile.com/thumb/5/13011190119.jpg
http://img2.putfile.com/thumb/5/13011190321.jpg
http://img2.putfile.com/thumb/5/13011190359.jpg
I have also had the battery relocated to the boot, a lot of tidying to do yet but you get the idea, its an Optima yellow top with custom bracket and fitting kit
http://img2.putfile.com/thumb/5/13011190267.jpg
Also got the new T67 DBB fitted in place now with oil and water braided lines and 4 row intercooler pipe work in place, all on a HKS manifold and HKS wastegate set up, down pipe to be made Monday
http://img2.putfile.com/thumb/5/13011190381.jpg
http://img2.putfile.com/thumb/5/13011190170.jpg
http://img2.putfile.com/thumb/5/13011190278.jpg
Couple with the Carbing strut brace and brake stopper (not fixed on as yet)
http://img2.putfile.com/thumb/5/13011190242.jpg
http://img2.putfile.com/thumb/5/13011190222.jpg
A couple of the Aquamist system going in, nothing fixed in as yet
http://img2.putfile.com/thumb/5/13011190365.jpg
A couple of the new wheels (WED SA70's with Proxy Tyres)
http://img2.putfile.com/thumb/5/13011190130.jpg
http://img2.putfile.com/thumb/5/13011190137.jpg
http://img2.putfile.com/thumb/5/13011190156.jpg
One of the new Momo steering wheel
http://img2.putfile.com/thumb/5/13011190340.jpg
Last one of the engine, with polished inlet from Colin
Hope you like them, I am really excited about getting it up and running next week
I will have the Fluidyne rad and polished catch tank, water injection tank, top rad pipe etc going in Tuesday and will post more pics as it come together
  • Replies 61
Not far to go now Dean! How long till it's ready to map?
Finished for the run in Friday of next week all being well with Matt Harwood finishing the wiring, still lots of finishing to do, fit new HID's, AP Carbon pads, re-wire the NOS system etc, should be ready for full mapping after run in which if I get to take it to Japfest should only be a couple of weeks, Mark and I are hoping for some good numbers on this but more importantly a very responsive road car
Good to hear mate, fingers crosed it's ready for next week :)
Gaz1 just finished his 1.4 bar map today and seemed to be a bit blown away by the results, hopefully you'll feel the same after Ryans done his magic ;)
Looks like it's coming together. :thumbs:
Couple of things I spotted though.
In the first pic, it looks like the fuel filter has been wrapped in insulating tape or something. The bracket is grounded, as should be the filter. I doubt very much that it would cause you any problems, but worth removing the insulation for peace of mind so that it's grounded properly. It'll get battered to hell by road debris with or without it.....
In the second pic, it looks like one of the oil cooler hoses is contacting the hose running up the centre of the picture. Worth making that those hoses don't contact with anything because they'll quickly cut through whatever they're touching.
Which injectors have you done with?
Looking forward to seeing it finished!
Good to see it nearly there mate been a long time but well worth the wait. Hope it will be all ready for running in down to the Japfest 2008 nice run too for running the engine in keep us updated cheers Lui
There is a lot of finishing to do and to be honest it was a bit unfair snapping away and posting these pictures as Mark was right in the middle of working on the car and connecting/tidying things up but I could not wait!!
The fuel and oil pipes will all have supporting clips to keep them apart
I went with Siemens 890cc injectors in the end
Hehe. Too impatient! :D
Be careful with those injectors mate. I've got them, and as Ryan and I have found they're a pig to control at the low duty cycles you get at idle. I've been running mine with an AEM and the stock resistor pack to sort the impedance out. When my engine goes back in, I'm junking the stock resistor pack and using a peak and hold injector driver. Might be worth bearing in mind if you're going with the AEM.....
Best of luck!
