Aircon Advice
Scott
Any idea where the filters are for the aircon in the sup? I'm going to get it re-gassed and cleaned out to remove all the bacteria etc but i want to replace the filters too.
Any idea where to buy the filters? Any idea where in central scotland i can get my aircon re-gassed?
Thanks
Mines in the garage guys going to change the pollen filter before guys come in to re-gas it its about £30 for filter if you havent found out day or so let me know ill ask the dude at garage were pollen filter was
There is no pollen filter, you can discharge a can of anti bacterial cleaner in the cabin too remove some of the bacteria, however if you want it done properly a strip down of the evaporator and drip tray is required.
Thanks for that, couldn't find any info in the PDF that Nic posted either so i assumed that was the case.
I'll give it a go with the antibac cleaner. Hopefully that will do the trick. Its not bad, its just noticeable IYSWIM.
