pa06has Posted May 9, 2008 Share Posted May 9, 2008 MOT's coming up - and instead of putting the fog back on! im wanted to change the bulb in the rear cluster, and replace my reverse light with the fog light! Not really knowledgeable bout electrics - anyone done this? if so you got any instructions on how to do it?!! Thanks Guys Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 9, 2008 Share Posted May 9, 2008 There is a wiring diagram somewhere around, not sure, it MAY have been heckler who put it together. Quote Link to comment Share on other sites More sharing options...
pa06has Posted May 9, 2008 Author Share Posted May 9, 2008 thanks il have a little search!! Quote Link to comment Share on other sites More sharing options...
Pabs Posted May 9, 2008 Share Posted May 9, 2008 make sure the fog light is the drivers side reverse light - not the passenger side. 12v signal from dash to illuminated switch on dash panel. From switch to bulb in o/s reverse light - change bulb for red bulb, connect other bulb connection to gnd. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 9, 2008 Share Posted May 9, 2008 http://mkivsupra.net/vbb/showthread.php?t=80479 Quote Link to comment Share on other sites More sharing options...
