Urgent advice needed.
Jake
I was just wondering...
if, hypothetically, my friend had dropped my their last can of Stella on a hard tiled floor at, for arguements sake, 23.55 BST when would be the earliest they could open it without needing to replaster the ceiling before SWMBO notices?
:innocent:
  • Replies 52
No need to search I know it is true. It was only last week I bought my mate a can of coke and shook it all the way back from the machine, stood beside him and vigorously shook it. After his spat at moaning I done the tapping method and hey presto it opened up as normal and did not spill a drop.
All I know is, if I dropped a can of Stella. It would probably hit me on the back of the head......;)
H.
If you would drop it, it would prolly dissapear for a while and then hit the floor in the kitchen :p :D
I bet he was slightly annoyed that it was so flat though.
Was it perhaps a cold can of coke, seeing as it came from the machine, and one of those links RedM supplied explains quite clearly why a cold can won't fizz up regardless of intricate tapping sequences? Did you perchance try three cans, one shook, one not shook, and one shook and tapped? That'd be a nice basis to come from rather than a one off :)
I know someone who tapped the can periodically for about two minutes and then claimed the tapping worked when it didn't fizz up. So, the two minutes it sat unopened didn't have anything to do with it then :rolleyes:
You should be a science teacher Ian :D
