Multics Posted May 8, 2008 Share Posted May 8, 2008 Getting really tired of the release bearing rattling now and as I'm planning to go NA-TT soon, I thought it's time to change the clutch and this effing bearing. Which clutch would you recommend? OEM? Quote Link to comment Share on other sites More sharing options...
edge Posted May 8, 2008 Share Posted May 8, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=135905 Some good ones on there Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted May 8, 2008 Share Posted May 8, 2008 Getting really tired of the release bearing rattling now and as I'm planning to go NA-TT soon, I thought it's time to change the clutch and this effing bearing. Which clutch would you recommend? OEM? Your release bearing?? Remember that post i put up regarding a rattling gearbox, what does your release bearing sound like when it rattles?? Mine is like, i suppose the only way i can describe it is like a rollercoaster climbing...its like a cha-cha-cha-cha-cha-cha noise... Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 9, 2008 Share Posted May 9, 2008 Getting really tired of the release bearing rattling now and as I'm planning to go NA-TT soon, I thought it's time to change the clutch and this effing bearing. Which clutch would you recommend? OEM? Will you convert NA to T or swap engine to TT one? If first option - go for TRD NA clutch, it will hold NA-T powers, if you are going to put TT engine - go for TT OEM clutch Quote Link to comment Share on other sites More sharing options...
Nic Posted May 9, 2008 Share Posted May 9, 2008 Getting really tired of the release bearing rattling now and as I'm planning to go NA-TT soon, I thought it's time to change the clutch and this effing bearing. Which clutch would you recommend? OEM? Definitely OEM. Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted May 9, 2008 Share Posted May 9, 2008 Getting really tired of the release bearing rattling now and as I'm planning to go NA-TT soon, I thought it's time to change the clutch and this effing bearing. Which clutch would you recommend? OEM? Why dont you go with a RPS clutch from klysett on the forum?? There's loads of choice which clutch you can have... Thats what im going to do because im now convinced my release bearing is rattling! Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted May 9, 2008 Share Posted May 9, 2008 Your release bearing?? Remember that post i put up regarding a rattling gearbox, what does your release bearing sound like when it rattles?? Mine is like, i suppose the only way i can describe it is like a rollercoaster climbing...its like a cha-cha-cha-cha-cha-cha noise... Hmmz, that sounds more like this: http://www.mkivsupra.net/vbb/showthread.php?t=148326 Quote Link to comment Share on other sites More sharing options...
Multics Posted May 9, 2008 Author Share Posted May 9, 2008 Why dont you go with a RPS clutch from klysett on the forum?? There's loads of choice which clutch you can have... Thats what im going to do because im now convinced my release bearing is rattling! I've been looking at those as well, it's a good option. It's quite difficult to describe the rattling noise, I might as well record it and post it here. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 9, 2008 Share Posted May 9, 2008 (edited) Why dont you go with a RPS clutch from klysett on the forum?? Complete overkill on an NA, no reason to fit anything other than stock clutch, it is more than up to the job and will be the quietest and smoothest option. Edited May 9, 2008 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Multics Posted May 9, 2008 Author Share Posted May 9, 2008 Complete overkill on an NA, no reason to fit anything other than stock clutch, it is more than up to the job. The thing Nic is that I will eventually go NA-TT (that is if my NA doesn't sell to get a proper TT). So I need a clutch that can hold TT BPU power. Does the TT OEM clutch fit in the NA housing? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 9, 2008 Share Posted May 9, 2008 Does the TT OEM clutch fit in the NA housing? No. You may want to consider fitting a TRD clutch housing and clutch discs in that case. Quote Link to comment Share on other sites More sharing options...
Multics Posted May 9, 2008 Author Share Posted May 9, 2008 Here's a quick vid. Hopefully someone can tell me if it's the release bearing rattling or not. http://www.youtube.com/watch?v=M4z59kiYSuw Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted May 11, 2008 Share Posted May 11, 2008 Here's a quick vid. Hopefully someone can tell me if it's the release bearing rattling or not. http://www.youtube.com/watch?v=M4z59kiYSuw Yep definetely 100% that IS your release bearing Multics. My n/a made the exact same noise... Although i am led to believe, TT release bearing rattle's, are different... Quote Link to comment Share on other sites More sharing options...
SilverSoop Posted May 11, 2008 Share Posted May 11, 2008 Hmmz, that sounds more like this: http://www.mkivsupra.net/vbb/showthread.php?t=148326 No Lebsteif, my gearbox was repaired with no faulte except a rattling from somewhere which the technicians could not diagnose. I then took the car to James at Toyota GT and within seconds, diagnosed it as a release bearing rattle... Quote Link to comment Share on other sites More sharing options...
