Bryan_Jones Posted May 8, 2008 Share Posted May 8, 2008 Now I have a serious problem :( I was accelerating away from a junction and my engine went bang! Immediately the engine management light came on and the hazard warning in the middle of the rev counter. Now the car won't rev over 2k else it cuts power completly, but doesn't stall. The engine sounds lumpy on tick over. Does it sound like one of the Turbos has gone? I knew it wasn't right. In this post: http://www.mkivsupra.net/vbb/showthread.php?t=149510 But now I think it's game over How much would it cost to replace the turbos? (if that's what it is) I have it booked in at Toyota in Bournemouth tomorrow morning to see what the issue is. Might look elsewhere for parts and fitting. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 8, 2008 Share Posted May 8, 2008 It sounds like an intercooler pipe has popped off, it's very common, but scares the hell out of you the first time Is there any black smoke from the exhaust? Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 No, there's no smoke. Which to be honest I was expecting if the Turbo had gone. Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 Where is the intercooler pipe? As soon as I know I'll go and check it out. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 8, 2008 Share Posted May 8, 2008 Have a really good look around the IC pipes, especially those around around the the intercooler itself. Do you have an aftermarket IC? Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 8, 2008 Share Posted May 8, 2008 Where is the intercooler pipe? As soon as I know I'll go and check it out. one pipe goes from the turbos into the driver side wing -intercooler- then the other one heads acros the front of the car and up then into the engine. Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 I have a stock intercooler. I'm going to have a look outside. Cheers for your help. Wish me luck! Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 8, 2008 Share Posted May 8, 2008 also mate we had similar issue with a supra recently same symptons as yours it was the ignitor pack Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 No joy Took off the cover in the wheel arch to look at the intercooler. It's definately on there good and solid. Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 also mate we had similar issue with a supra recently same symptons as yours it was the ignitor pack Where is the ignitor pack? Is there something I can look for? Quote Link to comment Share on other sites More sharing options...
michael Posted May 8, 2008 Share Posted May 8, 2008 No joy Took off the cover in the wheel arch to look at the intercooler. It's definately on there good and solid. How about the pipes running across to the other side of the bay? Have you followed the full run to check for popped hoses? Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 I think I'm going to need to. I'm going back outside now to have another look. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 8, 2008 Share Posted May 8, 2008 Where is the ignitor pack? Is there something I can look for? its located on the strut top of passenger inner wing (engine bay).. little black box.. you need to borrow one to test it takes 2 mins to remove thinks its 2 clips and x3 10mm nuts Quote Link to comment Share on other sites More sharing options...
Ric Posted May 8, 2008 Share Posted May 8, 2008 hose doesent have to have popped off, could be a split hose, remove them all and check them Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted May 8, 2008 Author Share Posted May 8, 2008 The hoses are big. I didn't manage to get back outside as I've been very busy taking calls for my business. So am I checking the 2 large pipes or other small ones? It's quite dificult to see. If I start the engine will I hear any noise coming from the pipe if it's split? Please excuse my stupid questions, but I'm trying to learn Quote Link to comment Share on other sites More sharing options...
Stevie72 Posted May 8, 2008 Share Posted May 8, 2008 My Intercooler went when i first bought mine and the engine went into Limp mode and wouldn't allow me to go above 2,000 rpm. Mind you mine was bellowing black smoke and you could hear the air blowing out when revving. Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted May 8, 2008 Share Posted May 8, 2008 suprise...i would have thought you would be able to rev over 2k with a split/disconected ic pipe? Quote Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2008 Share Posted May 8, 2008 Blown off intercooler pipes, while quite common on Supras running above stock boost, do not cause the engine to not be able to rev above 2000rpm. I've blown IC hoses several times and managed to drive home on the motorway just fine. (Not a great idea though as the engine is ingesting unfiltered and unmetered air) Start by reading your error codes and report back. - - - - - Edit to add: shouldn't "error codes" hyperlink to the explanation? Or don't we do that anymore? Quote Link to comment Share on other sites More sharing options...
Jake Posted May 8, 2008 Share Posted May 8, 2008 My Intercooler went when i first bought mine and the engine went into Limp mode and wouldn't allow me to go above 2,000 rpm. Limp Mode? Isn't that only on VVTi Supras? (due to the FBW) Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 8, 2008 Share Posted May 8, 2008 take my advise this happen to me 2 weeks ago Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted May 8, 2008 Share Posted May 8, 2008 "Blown off intercooler pipes, while quite common on Supras running above stock boost, do not cause the engine to not be able to rev above 2000rpm. I've blown IC hoses several times and managed to drive home on the motorway just fine. (Not a great idea though as the engine is ingesting unfiltered and unmetered air)" me too.....? Quote Link to comment Share on other sites More sharing options...
Homer Posted May 8, 2008 Share Posted May 8, 2008 Edit to add: shouldn't "error codes" hyperlink to the explanation? Or don't we do that anymore? Good point, it should. There were some problems with the hyperlinks mentioned before, reported for Mawby to take a look... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2008 Share Posted May 8, 2008 Down the side of the battery nearest the middle of the car. It may not LOOK as if it's blown apart, but serious tugging and messing may well show the rubber to vertical plastic pipe union is no longer fully intact. Quote Link to comment Share on other sites More sharing options...
Alex Posted May 9, 2008 Share Posted May 9, 2008 The 2000rpm thing could be due to a lack of available air due to the pipe fault. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 9, 2008 Share Posted May 9, 2008 The same thing happened to me after some work was done on my car. It sounds terrible, but it was only one of the intercooler pipes popping off. Luckily I was on my way to the garage at the time, so they tightened it all up and haven't had a problem since. Well I hope that's all it is for you, as second-hand turbos and fitting them isn't particularly cheap! As I know full well Quote Link to comment Share on other sites More sharing options...
