QSC Posted May 8, 2008 Share Posted May 8, 2008 Having read up on how to check your narrowband O2 sensor reading, I am now confused as to why it is reading 0.03 volts from the OX1 pin on the diagnostic panel, when the How To article says it should be approx 0.7 - can anyone shed any light on this ? Testing the battery shows the correct 14.3 volts. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 8, 2008 Share Posted May 8, 2008 The sensor is bust? Are you experiencing poor fuel economy and failing emissions tests? -Ian Quote Link to comment Share on other sites More sharing options...
QSC Posted May 8, 2008 Author Share Posted May 8, 2008 Ah - welcome to the grandmaster of things O2 related - I am experiencing rather poor fuel economy, but, alas, I go to one of those friendly garages that politely ignores the emissions test - overnight soak in lemon commencing anyway - Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 8, 2008 Share Posted May 8, 2008 It sounds like it's reading no signal at all rather than just a low one, so it might be a terminal sensor or it might be a wiring issue, but the lemon soak move is a very good cheap first stab at fixing it Don't ignore emissions tests, they can be very handy at diagnosing problems Just don't submit the results to the red tape brigade -Ian Quote Link to comment Share on other sites More sharing options...
QSC Posted May 8, 2008 Author Share Posted May 8, 2008 It sounds like it's reading no signal at all rather than just a low one, so it might be a terminal sensor or it might be a wiring issue, but the lemon soak move is a very good cheap first stab at fixing it Cheap ? 28p that cost me + £4.49 for a deep socket Don't ignore emissions tests, they can be very handy at diagnosing problems Just don't submit the results to the red tape brigade : Thanks for the advice, it's just the hassle of re-fitting the cat I can't be bothered with Quote Link to comment Share on other sites More sharing options...
