Trimming Number Plates
Daston
Very easy.Measure on BOTH sides where you want the cut line.
Hold a straight edge,pref a metal rule (if you doubt your skills double sided tape the rule to the number plate ).Using a stanley knife with a new blade score a line on the number plate.Re score this 3-4 times.Put the rule the opposite side and do the same thing.Using a pair of pliers holding them close to the line,snap off the unwanted piece,sand smooth to finish.
Just be careful with the first cut,good pressure and a firm grip....:blink:
ah cool thanks! I was thinking of using a saw but that sounds far easier and cleaner
