Power Steering Noise
SimonT
Wonder if anyone could shed any light on this.....
When i start my car the power steering whines until i have driven it for about 15 mins then it shuts up!!!
Is my pump broken or is it something else and if so is it a huge issue????
Much appreciated if anyone could help!!!
My power steering now makes the noise for an even longer period of time and it doesnt seem to stop until i have driven it for about 30 mins!!
Is this still an air lock problem or are the barings knackered in the pump and does it need changing as the noise is quite loud??!!
Any advice would be very much appreciated!!
Try a new PAS fluid reservoir, the nylon gauze in the bottom that filters the oil is probably blocked with sediment, the thinner, hot oil passes more freel, the cold, more viscous oil makes the pump sweat and whine. Could also be drawing air form a hardened O ring on the suction side, which softens and swells as the oil heats up.
