Fuel system
Steve Cargill
From what I've picked up the following is roughly true. This is without boost controller, fuel computers or ECU changes.
J spec pump & injectors are OK up to about 18PSI (along with the J spec turbos)
With hybrids they are only OK to about 15PSI
If I put UK 550's and resistor on with J spec turbos there is no benefit and I'm over-fuelling. The fuel pump may also be borderline for this flow.
550's with UK pump on hybrids should be OK for 18PSI
Done a bit of trawling and come up with the following parts list for the upgrade. Any other biits needed, pipes clips etc etc.
Injector 6* 23209-49035
Resistor 1* 28510-46020
Fuel pump 1* 23221-46110
