Guest D15RTY Posted February 10, 2005 Share Posted February 10, 2005 who does the blue led dash conversion and does it include the dials also how £ is it Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 You can get bulbs from http://www.superlumination.com/. Gaz Link to comment Share on other sites More sharing options...
michael Posted February 10, 2005 Share Posted February 10, 2005 'SupraTTmyster' (Emin) is the man to speak to Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 who does the blue led dash conversion and does it include the dials also how £ is it Do it your self... I did http://www.internetwork.org.uk/led/dash1.jpg http://www.internetwork.org.uk/led/dash2.jpg But if you want to save you self the hassle, Emin's the man... I belive £150 fitted... best check with Emin :burb: Link to comment Share on other sites More sharing options...
terribleturner Posted February 10, 2005 Share Posted February 10, 2005 Do it your self... I did Did you get the bulbs from the above link that Gaz posted?? Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 Heckler, nice job on your interior lights! I'm in the process of sorting mine out but what size bulbs are for the control panel facia (heater ets), BA9's? What about the clocks? Cheers, Gaz Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 Did you get the bulbs from the above link that Gaz posted?? I used LED's from maplin Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 Did you get the bulbs from the above link that Gaz posted?? Hi Trevor, I need to get this sorted 'rapid' but struggling to find the right bulbs. You did yours too didn't you? Thanks for your email by the way. Gaz Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 I used LED's from maplin Aha, I see. Where they all the same size/model? What sort of cost? Gaz Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 Aha, I see. Where they all the same size/model? What sort of cost? Gaz Its a mixture of 3mm and 5mm LED's I think looking at around £30 for the LED's, plus resistors... You solder them on. Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 Its a mixture of 3mm and 5mm LED's I think looking at around £30 for the LED's, plus resistors... You solder them on. Thanks Heckler, I'll compare prices between Maplin and Trevor's link. I've put this off for too long now, so I need to get on board and get it sorted! Gaz Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 ...does it include the dials... Hi, there was a group buy on here a while ago on new dials. Email 'PaulE' about some El-Glo dials, very nice. About £130.00 Dials come with a converter that changes the glow from Blue to Green, depending on your mood. Hope this helps. Gaz Link to comment Share on other sites More sharing options...
terawua Posted February 10, 2005 Share Posted February 10, 2005 I have the blue dials... very nice.... if you get the uprated inverter, it also has the correct connection to wire up a piece of eletroluminescent wire which you can buy from maplin or PC world, and then you can dim the whole lot.... very nice. The maplin LED's are the 3mm blue... NOT the blue tint (check the order codes) as these look cack - imagine my seething fury when after I had spent about 3 hours soldering to find that my LED's were a mixture of the plain blue and the tint.. its 2 years on and I still haven't fixed it.... oh and by the way.. I have a set of blue tint LED's for sale ;-) Link to comment Share on other sites More sharing options...
terawua Posted February 10, 2005 Share Posted February 10, 2005 sorry I should have pointed out that you run the wire through the Air conditioning unit to illuminate it The LED's are for the indicator LED's on the Air coniditioning unit.... Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 sorry I should have pointed out that you run the wire through the Air conditioning unit to illuminate it The LED's are for the indicator LED's on the Air coniditioning unit.... Got any pics of your install...step by step or night shots? How bright are those tinted ones you've got for sale? Gaz :flame Dev Link to comment Share on other sites More sharing options...
MrAngry Posted February 10, 2005 Share Posted February 10, 2005 Just ordered the bits from Maplins to do the job apart from the bits for the dials they will be the next job That should keep me entertained for a couple of hours Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 Just ordered the bits from Maplins to do the job apart from the bits for the dials they will be the next job That should keep me entertained for a couple of hours did you get the resistors and diode? Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 Just ordered the bits from Maplins to do the job apart from the bits for the dials they will be the next job That should keep me entertained for a couple of hours Have you still got your shopping list... 20 x 3mm LED's? 10 x 5mm LED's? Give us a clue...how many do i need? Cheers Gaz Link to comment Share on other sites More sharing options...
terawua Posted February 10, 2005 Share Posted February 10, 2005 SilverMachine... I dont have pics.. but can do some..... will post them tonight.. and you will see which colour your prefer as they are right side by side in my install (which I need to change as I already mentioned) Sorry the for sale thing was a little tongue in cheek. I dont recommend getting the tints. I will just be using them to exchange for the correct ones - Mapling said I should have tested them before put them in as they were not able to accept them once the legs were cut ont he LED's. If you want instructions on parts and fitting you can get them off Pete Betts personal website (see his profile on here - electronics guru) cheers James Link to comment Share on other sites More sharing options...
MrAngry Posted February 10, 2005 Share Posted February 10, 2005 For the heater controls you need 16 x 3mm Blue LED's 1 x 6v2 diode or for dimmer lights 1 x 5v6 diode 7 x 390R resistors to match the brightness of all the LED's as the amber and green use different currents. The resistors aren't required if you don't mind variation in the brightness from what where the old green and amber LED's Link to comment Share on other sites More sharing options...
SilverMachine Posted February 10, 2005 Share Posted February 10, 2005 For the heater controls you need 16 x 3mm Blue LED's 1 x 6v2 diode or for dimmer lights 1 x 5v6 diode 7 x 390R resistors to match the brightness of all the LED's as the amber and green use different currents. The resistors aren't required if you don't mind variation in the brightness from what where the old green and amber LED's Thanks Angry! A trip to Maplins on Saturday me thinks! Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 For the heater controls you need 16 x 3mm Blue LED's 1 x 6v2 diode or for dimmer lights 1 x 5v6 diode 7 x 390R resistors to match the brightness of all the LED's as the amber and green use different currents. The resistors aren't required if you don't mind variation in the brightness from what where the old green and amber LED's Hmmm... I wonder where you got that from Link to comment Share on other sites More sharing options...
MrAngry Posted February 10, 2005 Share Posted February 10, 2005 Hmmm... I wonder where you got that from Some nice chappy told me Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2005 Share Posted February 10, 2005 Some nice chappy told me Link to comment Share on other sites More sharing options...
mr keef Posted February 10, 2005 Share Posted February 10, 2005 Can ya not just change all the bulbs in the dash as some of mine aint workin?how much?how many?do i need,and get ya get blue bulbs? Link to comment Share on other sites More sharing options...
