SupraRider Posted May 5, 2008 Share Posted May 5, 2008 Hi Peeps, I hope you can help..I own a 93 J-Spec N/A auto. the overdrive button has been working fine when I pressed on the button, the car dropped from 4000RPM to 3000RPM when I'm accelerating at 70mph. recently, I noticed the car is not responding to it, I'm always driving at 4000RPM at 70mph on the motorway.. Can someone tell me what's wrong? Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted May 5, 2008 Share Posted May 5, 2008 Does the dash light still come on when you press the button? If it doesn't then the two wires from the O/D button to the loom could have been damaged somewhere along the way - happened to mine a few months back, as the wires had come free of its securing clips, got caught on the lever's mechanisms and then seperated. New button assy's about £30 from Mr T. Quote Link to comment Share on other sites More sharing options...
carl0s Posted May 5, 2008 Share Posted May 5, 2008 Have you left MANU on ? Quote Link to comment Share on other sites More sharing options...
SupraRider Posted May 11, 2008 Author Share Posted May 11, 2008 hi guys, thanks for writing, apologies for not getting back sooner...the dash light goes off when I press on the O/D button,works as normal,the car just doesn't seemed to respond fast enough, when it does, it goes great for a while, then the car start to get into high revs again,this happens even when the O/D button is pressed. As for the MANU button, my MANU button isn't working. Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted May 11, 2008 Share Posted May 11, 2008 As for the MANU button, my MANU button isn't working. The Manu, O/D, Trac etc systems are all interconnected at different points and share many of the same feeds, so not having a working Manu button could be screwing up the O/D further along the line, as they all send inputs to the same place. I'd check the wiring/connections behind your Manu button just to make sure it's nothing simple and dig further if necessary until I get it working properly. If the problem still occurs with a working Manu button then it's something a bit more involved unfortunately. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
SupraRider Posted May 11, 2008 Author Share Posted May 11, 2008 The Manu, O/D, Trac etc systems are all interconnected at different points and share many of the same feeds, so not having a working Manu button could be screwing up the O/D further along the line, as they all send inputs to the same place. I'd check the wiring/connections behind your Manu button just to make sure it's nothing simple and dig further if necessary until I get it working properly. If the problem still occurs with a working Manu button then it's something a bit more involved unfortunately. Let us know how you get on. Hi Mike, Thanks for that, do you know where I could get that checked? I live up here in Scotland, would you recommend going to a toyota dealership?bet they'll rip me off since they don't know what they're talking about... any ideas please? Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted May 11, 2008 Share Posted May 11, 2008 Difficult to say. I'd personally start stripping things out and looking for bad/loose connections myself first, before I took it anywhere, but it depends on your mechanical knowledge. There's plenty of wiring diagrams out on t'net to help you also. I don't know if there's any Supra specialists up near L & B either, unless you count Envy in Northumberland. Maybe someone else who's further North than I am now could help? If not then i'd see if there's any decent auto-electricians in your area and go from there. Mr T may charge a lot, but they should be able to sort it out as a last resort. Hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
SupraRider Posted May 11, 2008 Author Share Posted May 11, 2008 Difficult to say. I'd personally start stripping things out and looking for bad/loose connections myself first, before I took it anywhere, but it depends on your mechanical knowledge. There's plenty of wiring diagrams out on t'net to help you also. I don't know if there's any Supra specialists up near L & B either, unless you count Envy in Northumberland. Maybe someone else who's further North than I am now could help? If not then i'd see if there's any decent auto-electricians in your area and go from there. Mr T may charge a lot, but they should be able to sort it out as a last resort. Hope you get it sorted. sure, I'll see if I can find an auto electrician first before going to Mr. T. sorry I'm not at expert in mechanical stuff about cars at all. Quote Link to comment Share on other sites More sharing options...
