Guest putputcar Posted May 4, 2008 Share Posted May 4, 2008 Hi all, I need some wiring help on installing a spal 7.5" fan on my transmission cooler. Here is the link of the instruction of the fan controller. http://www.haydenauto.com/pdf/instruction-sheets/P-475-3647-fan-controllers.pdf On page 1, second column, #3, "Yellow wire (ignition signal)- Attach the yellow wire to a positive (+) 12 volt connection that is controlled by the ignition. To allow fan(s) to operate with the ignition off, connect the yellow wire to a constantly live (hot) lead." Do you all know which wire in the engine bay that is a 12 volt controlled by ignition switch? (12 volt only when key is ignition on position, NOT constant 12V when the key is off) Your help is much appreciated in advance. Thanks Quote Link to comment Share on other sites More sharing options...
Guest putputcar Posted May 10, 2008 Share Posted May 10, 2008 Found one on the manual. Thanks Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted May 10, 2008 Share Posted May 10, 2008 no problem mate and to the club Quote Link to comment Share on other sites More sharing options...
