RobSheffield Posted May 2, 2008 Share Posted May 2, 2008 Hi guys Iv done a search, but drawn a blank. Im refitting the TPS back to my throttle body, but does it need 'setting up' in any way? I am sure i once read that you need a multimeter to set it. I just need precise instructions to refit if they are available. Thanks Link to comment Share on other sites More sharing options...
Ryan.G Posted May 2, 2008 Share Posted May 2, 2008 Rob Just put the screws in the centre of the Tps adjustment gaps as you have an Aem and can calibrate the TPS through the ECU. I will tell you how to do this when setting up the base map. For owners that dont have a TPS though you need to follow the below http://www.mkivsupra.net/vbb/showthread.php?t=51981&highlight=throttle+tps Link to comment Share on other sites More sharing options...
RobSheffield Posted May 2, 2008 Author Share Posted May 2, 2008 Great stuff, cheers Ryan Link to comment Share on other sites More sharing options...
