Guest Sizer Posted February 9, 2005 Share Posted February 9, 2005 Whats the average MPG for a n/a and TT? Quote Link to comment Share on other sites More sharing options...
Faye Posted February 9, 2005 Share Posted February 9, 2005 My NA averages about 18-20mpg Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted February 9, 2005 Share Posted February 9, 2005 My NA averages about 18-20mpg So does my TT. You should note that Faye has an aftermarket exhaust and decat, which will consume a little more fuel over standard. The actual MPG isn't much different between them, however, you can get away with putting normal unleaded fuel in an NA. Jap TT's need expensive Optimax or Ultimate really (as they are designed for higher RON fuels in the mother land) Quote Link to comment Share on other sites More sharing options...
Guest Sizer Posted February 9, 2005 Share Posted February 9, 2005 ooooo....I thought the TT would use alot more, someone somewhere quoted 15mpg. Thought it may be a factor when making a decision but i guess not. Mind you I dont know what my car uses!....i know its alot..lol Quote Link to comment Share on other sites More sharing options...
terribleturner Posted February 9, 2005 Share Posted February 9, 2005 Mine does on average 16 , and that's J-spec TT. Think Oxy gets 19/20 odd on his though. Quote Link to comment Share on other sites More sharing options...
attilauk Posted February 9, 2005 Share Posted February 9, 2005 i get about 22 - 24mpg on a motorway trip about 20mpg in towns and about 16 - 18mpg on "spirited" drives through the country on my way back from germany i got 31mpg! but that was on 100 octane fuel on a track day i get about 6mpg Quote Link to comment Share on other sites More sharing options...
Faye Posted February 9, 2005 Share Posted February 9, 2005 So does my TT. You should note that Faye has an aftermarket exhaust and decat, which will consume a little more fuel over standard. The actual MPG isn't much different between them, however, you can get away with putting normal unleaded fuel in an NA. Jap TT's need expensive Optimax or Ultimate really (as they are designed for higher RON fuels in the mother land) Did the same MPG bone stock too Quote Link to comment Share on other sites More sharing options...
Guest Sizer Posted February 9, 2005 Share Posted February 9, 2005 I got one of each to look at at the weekend so at least i know i dont need to factor the MPG in... Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted February 9, 2005 Share Posted February 9, 2005 Did the same MPG bone stock too I'll shut up then! Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted February 9, 2005 Share Posted February 9, 2005 I got one of each to look at at the weekend so at least i know i dont need to factor the MPG in... Auto's will use a little more fuel Quote Link to comment Share on other sites More sharing options...
terribleturner Posted February 9, 2005 Share Posted February 9, 2005 on a track day i get about 6mpg The road IS my track Quote Link to comment Share on other sites More sharing options...
geoffvalenti Posted February 9, 2005 Share Posted February 9, 2005 I'm getting about 16-18mpg (TT auto) around town/short runs these cold days, maybe a bit more when the weather warms up a bit. I don't drive with economy in mind but its not all foot hard down thrashing either. Cars like the Supra just aren't built for economy. It doesn't really worry me, but it probably would if I was doing 20-30k miles per year As for the difference between TT and N/A, personally I don't think there's going to be a lot in it, fuel consumption wise. Quote Link to comment Share on other sites More sharing options...
Jake Posted February 9, 2005 Share Posted February 9, 2005 I usually get about 280 to 300max from a tankfull. That's mainly motorway driving. When we did the mkivsupra.net trip to Amsterdam in Sep 03 I was getting about 7mpg during the highspeed bits (130 to 150mph for 30odd miles) You can almost see the fuel gauge needle moving at those speeds. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted February 9, 2005 Share Posted February 9, 2005 im a NA and do 135miles almost every time to £20 of unleaded...dont know what that equals Quote Link to comment Share on other sites More sharing options...
attilauk Posted February 9, 2005 Share Posted February 9, 2005 about 24mpg mate god im bored Quote Link to comment Share on other sites More sharing options...
Sharpie Posted February 9, 2005 Share Posted February 9, 2005 I have no idea and don't wish too Quote Link to comment Share on other sites More sharing options...
tbourner Posted February 9, 2005 Share Posted February 9, 2005 Technically a turbo car will have better fuel economy than it's NA counterpart, up to a certain percentage of throttle activation (not sure on the percentage, guess about 10-15%). There's a VERY detailed explanation of why this is and it can be explained in entire volumes of text!! But basically it's because there is no loss due to induction charge robbing and exhaust return that you get on 2 of the 4 strokes in a NA engine. The exhaust and charge are under various pressures and the crank doesn't loose energy by drawing in or pushing out gasses from the cylinder (also why putting a big free flowing exhaust on a NA messes up the power curves), even on idle the turbo helps prevent these problems. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted February 9, 2005 Share Posted February 9, 2005 Average 15mpg here. PS. Anyone else find TerribleTurners avatar somewhat hypnotic Quote Link to comment Share on other sites More sharing options...
terribleturner Posted February 9, 2005 Share Posted February 9, 2005 PS. Anyone else find TerribleTurners avatar somewhat hypnotic Just incase you needed to see it again "You are all under my spell, Buy me loads of things for goodies for my car!!!" Quote Link to comment Share on other sites More sharing options...
Muffleman Posted February 9, 2005 Share Posted February 9, 2005 I've got sod-all done today as it is Quote Link to comment Share on other sites More sharing options...
Getrag Posted February 9, 2005 Share Posted February 9, 2005 Lol, im sad and put it all down on a spreadsheet. Im averaging 21mpg right now WITH the below mods. Suffice to say, im one of the "slower" drivers Still manage to get the back end out on a daily basis though Quote Link to comment Share on other sites More sharing options...
Holly Posted February 9, 2005 Share Posted February 9, 2005 With most being motorway (M25) commuting, we get a very impressive 24 mpg. On track days it's more like 8. UK MkIV TT Auto (With a few mods) Quote Link to comment Share on other sites More sharing options...
MrAngry Posted February 9, 2005 Share Posted February 9, 2005 I'm getting combined 24mpg, and on the motorway I usually get around 26-27mpg Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted February 9, 2005 Share Posted February 9, 2005 im a NA and do 135miles almost every time to £20 of unleaded...dont know what that equals SHIT!!! My TT does 170 miles to £55 of optimax in summer, and 200 miles to the same amount of optimax in winter. Anyone want to figure out my MPG?? Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted February 9, 2005 Share Posted February 9, 2005 I used to get GREAT MPG. Newcastle Upon Tyne - London = .75 of a tank Quote Link to comment Share on other sites More sharing options...
