Oil Feed Gasket For Single Turbo
Kev.O
try gt3turbo.com mate.. they do most of them..
Thank you. The only oil feed gasket I can find is this one but it says it's for a T3, does anyone know if it will fit a T61 as I can't see the oil feed being a different size for different turbos :search:
Turbo Dynamics have them, and can supply billet fittings too.
I have the billet fitting from the BL oil kit but require a new gasket for it.
Thanks for the replies guys, hopefully the gasket I've ordered will fit.
What gasket are you putting on it? Most just run an AN fitting off the hose right into the turbo.
The GT4088 required the billet fitting as it wasn't tapped and thought I may aswell keep the billet fitting.
