mirror finish supra badge
captainchaos
it was just a test to be honest, but if people are interested in them why not.
Guigsy do you want mirror finish or brushed finished stainless.
Im busy getting quite a few designs done:
Supra slam panels
Slam panel incorporating rad cover etc (stainless and bent up)
Skyline slam panels
Air diversion plates
Covers for inner wings
Sub guards/defenders
badges/logo's various makes and models
Busy designing plug cover at the min, machined from ally
Made a harness bar up for the back of my supra.
Whn i get it running properly its coming into the factory to have a cage custom made and the trial rear end ally boxed into the rear subframe to stop drag being caused by it and reducing the chance of it wanting to go bouncing down the road.
Done quite a few badges/logos in the past for peoples boot builds with a couple of bolts welded onto the back so they can be attached and then pulled into the foam giving a flush look.
You name it really if i can draw it on the comp i can make it somehow.
I wonder if you could make a slam panel that's the Supra logo? A few mounting points might need adding of course and it won't force air through the rad / IC but it would look a bit different to the norm.
Had a quick tinker with that idea to get the whole supra logo in the space, none of the original holes are in the right position, but im some hidden bracketry could be made up for it
The brackets could always be painted black to hide them anyway I guess - would look quite nice though, or maybe the TRD logo as that's a bit more suited to the shape of the hole.
Enough advertising get that trader status sorted ;)
been thinking about that, but probs as hobbiest for the time being as there are other things in the pipeline on a larger scale and need to see how they plan out first. As this company is my family company which is priority and im having to take more and more responsibility here as time goes on.
You obviously have the equipment and skill and there certainly is a market you should seriously think about it :)
But as you say it means taking time away from other areas.
Incidentally i think a 6 ft Supra badge would look cool for the club stand :cool:
Prices
prices as requested for badges from mirror finish 316 st/st
small 155 x 40 £5.00
med 310 x 80 £8.00 (as hodges)
large 1290 x 330 £35.00
3Ft long £45.00
4ft long £55.00
Slam panels £30.00 - £35.00 depending on etching etc
Delivery inc on smaller items and slam panels
Larger items i need to check out for delivery charges
Delivery inc for slam Panels.
