Multics Posted April 28, 2008 Share Posted April 28, 2008 Just trying to understand why the driver's side window does not push hard enough on the rubber seals around the top. The wind noise starts to annoy me (especially cos it starts around 55mph). I've found a previous post which also contains a pic with some white screws that supposedly ajust the angle of the window but can anyone please confirm if those white plastic bits are the ones to adjust in order to push the window towards the car. http://www.mkivsupra.net/vbb/showthread.php?t=134699&highlight=window+adjustment Cheers Link to comment Share on other sites More sharing options...
merckx Posted April 28, 2008 Share Posted April 28, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=148383 Link to comment Share on other sites More sharing options...
Multics Posted April 28, 2008 Author Share Posted April 28, 2008 I tried adjusting it by turning clockwise the right collar but nothing really happened. Are we talking about the same thing? Ta Link to comment Share on other sites More sharing options...
merckx Posted April 28, 2008 Share Posted April 28, 2008 Yes, that's it. It's a while since I did mine, but I think the adjustment was in the middle. The bracket is there just to hold it in the correct position after adjustment. There might be a plastic collar in the middle, if you have a good look you'll figure out how it works. Unless you're missing something. Link to comment Share on other sites More sharing options...
