Steve Posted April 26, 2008 Share Posted April 26, 2008 I need to find a Speed sensor input and a throttle position sensor input for my new EVC 6 boost controller. Just want to confirm i have the right pins at the ECU. Speed Sensor - E10 Pin 2 Throttle Position Sensor - E10 Pin 40 or E9 Pin 43 Which of the Throttle position sensor wires do i use? Does it not matter which? I got these Pinouts from here Thanks PPwbm Quote Link to comment Share on other sites More sharing options...
Steve Posted April 27, 2008 Author Share Posted April 27, 2008 Quote Link to comment Share on other sites More sharing options...
Steve Posted April 27, 2008 Author Share Posted April 27, 2008 Found this on mkiv.com for future reference for others. It shows the connections for RPM,Speed and Throttle Position. http://img2.putfile.com/thumb/4/11712054296.jpg Throttle Position - E9 Pin 43 Speed - E10 Pin 2 RPM - E9 Pin 58 Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted February 20, 2010 Share Posted February 20, 2010 cheers mate .I will try this diagram , but also my car has an auto ecu for now . Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 21, 2020 Share Posted May 21, 2020 Just found this don’t no if Steve is still about? But does anyone no if the Pin no are the same as a Uk spec Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted May 21, 2020 Share Posted May 21, 2020 http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts This should help.. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 21, 2020 Share Posted May 21, 2020 Thanks mate Quote Link to comment Share on other sites More sharing options...
