Ubuntu install has 'killed' my laptop!
RedM
During the install procedure my laptop screen went black and after about 10 minutes I could hear no more activity.
Now the machine won't power up. The lights flicker on for a second or two then nothing. The drive doesn't spin up and I can't get to the BIOS screen either.
Put the old XP drive in and still nothing!
WTF do I do now?
If you can get into your laptop and find the CMOS battery (its like a watch battery) take that out for a min or so along with your laptop's battery. This will clear the CMOS and take it back to factory default. While you are at it i would also take out the memory, give it a little clean and clean any fluff and dust from any of the fans as it sounds like your laptop is overheating.
As said, leave everything unplugged for a few mins then whack it all back together and give it a go. I get the same error from my wifes lapptop when she has had it sitting on her lap for hours. It turns itself off and i have to wait on it cooling down as it either won't turn on at all, or when it does it only stays on till it overheats again.
Hope that helps
Overheating?
I've just put a lovely 80gb drive in it this morning. I wonder if that's the problem.
Doubt it would be the HDD but you could give it a go. The HDD doesn't come into play until after the bios has done its thing. IF you were turning it on and it wasn't getting that far it definitely sounds like overheating.
Whether the harddrive is causing the overheating or not i have no idea but i would be surprised if it was.
I wouldn't have thought so. Age and dust, fluff is usually the main cause of overheating. If the fans weren't able to ventilate the system properly the CPU and RAM temps would go through the roof causing your computer to shutdown for safety.
The thing is, if your lappy has been sitting for a while now without any activity it should boot up. My wifes takes around 5-10 mins to cool down so that its safe enough to use.
If it's overheating, it's usually caused by dust turning into fluff and blocking the heatsink. Most laptops have a fairly fine-finned heatsink. Access to the CPU fan/heatsink is easy on most laptops and the fluff is usually on the innermost edge of the heatsink where it comes into contact with the fan.
Laptop now runs for about five minutes then goes black!
On the plus side I'm on a full Ubuntu install on our main PC despite some scary GRUB error 21 message and the BIOS not recognizing the new HHD.
UPDATE: Laptop is, IMO, dead.
It won't stay on for more than 15-20 minutes at a time and died halfway through installing Ubuntu so now won't even boot as I wrote over the original 12gb drive!
It's weird that it decide to die/overheat on the day I put a new HDD in. Too much coincidence especially as it never shut down prior to that.
Time to buy a new one I s'pose.
I've got a defibrilator you could borrow... *zap*
No, in all honesty if it's running for five minutes I doubt it's a bad block issue on your hard drive(s). If it's running for 5 minutes then shutting down it sounds like something's reaching it's thermal envelope then going down like a sack of s*** to protect itself.
Heatsinks, mobo, CPU itself, not great to diagnose. Maybe you can boot it up to any OS and get some stat monitor that shows you CPU/Heatsink/GPU/HD heat levels?
Did you try taking it apart and cleaning out the fans?
I did. They weren't too bad TBH.
I'd try that but I've no idea how to get an OS to run on it when it won't stay on long enough to get one re-installed.
You need a place with low ambient temperature I guess (if it is a heat thing). Work outside late at night, or do you have a chest freezer you could temporarily climb in? :p
mmmm chilly.
