Gaz6002 Posted June 5, 2008 Share Posted June 5, 2008 Awesome project, I'm watching with interest mate Link to comment Share on other sites More sharing options...
spuduk99 Posted June 5, 2008 Share Posted June 5, 2008 That is a BIG turbo! Is it just the camera angle or will the turbo clash with your strutbrace? Link to comment Share on other sites More sharing options...
Terminator Posted June 5, 2008 Author Share Posted June 5, 2008 (edited) I think it is just the angle that makes it look like the turbo will hit the brace. I'll take it over and try it tonight. The turbo is a GT74, good for 750bhp to 800bhp at the wheels. Edited July 3, 2009 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
paul mac Posted June 5, 2008 Share Posted June 5, 2008 keep the pics coming Termy, i like your sig as well, there are far to many sheep in wolfs clothing round here Link to comment Share on other sites More sharing options...
Terminator Posted June 6, 2008 Author Share Posted June 6, 2008 (edited) As requested a shot of the inside of the Borla. The best I can do is through the Burns back box. The Borla has the additional longitudinal baffle plates running through the bore. Edited September 4, 2011 by Terminator Added information (see edit history) Link to comment Share on other sites More sharing options...
Terminator Posted June 6, 2008 Author Share Posted June 6, 2008 (edited) This evening we finished of the oil system; HKS kit with remote oil filter location with Greddy sandwich plate for oil pressure and oil temperature sensors. There is enough room between the PS lines and the air-con pump for the Lexus V8 oil filter. Finally fitted the oil cooler in its permanent place, a slightly different position to the test fit location. Just a few minor things to do on the fuel system, fit the FPR in its final position and mount the clip for the fuel filter. Everything has been checked and tightened up. Static timing done with the help of the Titan pulley. The build is almost complete, just a few final checks to carry out before we fill the engine with oil and wind the engine by hand and time the cams. Edited March 14, 2010 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
Terminator Posted June 7, 2008 Author Share Posted June 7, 2008 (edited) Fitted the peddles today and got the clutch working, it is hard to believe how light the OS Giken triple plate feels. It must be due to the multi levered pull to push conversion system. Getting ready for some heel and toe action:) This afternoon the boot battery was fitted and the relay switched feed to the fuel pumps was installed. We finally have battery power again. This evening I lubricated the cams and turned the motor over by hand several times to spread it around ready for when we turn the key. It is great having all the right equipment in MB Automotive's workshop, this powered wash bath beats the old washing up bowl full of white spirit. Washing out the polished cam covers, ready for their final fitting, was so easy. With a bit of luck this will be the last I see of the 280 HKS cams for a long time. We mainly have wiring to do now, work in the bay is almost over. Edited June 7, 2008 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
RobSheffield Posted June 7, 2008 Share Posted June 7, 2008 Wierd, my last major job before starting was fitting an oil cooler and filter relocator! Looking good Phil Link to comment Share on other sites More sharing options...
Thorin Posted June 8, 2008 Share Posted June 8, 2008 Wierd, my last major job before starting was fitting an oil cooler and filter relocator! Looking good Phil You're just trying to mention the fact that it's now running in as many threads as possible aren't you? But yes, looking good Phil! Link to comment Share on other sites More sharing options...
Terminator Posted June 11, 2008 Author Share Posted June 11, 2008 (edited) That is a BIG turbo! Is it just the camera angle or will the turbo clash with your strut brace? It is close but has enough clearance. Due to lack of space for a washer bottle in the bay at front near side, I made the original fit in the front off side wing. I used a hot gas iron to fuse the cut sides together, I did not bother to tidy up the seam as it is hidden under the car. Edited September 4, 2011 by Terminator Added information (see edit history) Link to comment Share on other sites More sharing options...
Joeatphr Posted June 11, 2008 Share Posted June 11, 2008 I see some of the progress and glad I could get you the rest of the parts! Everything is looking great but you need TTC Pedals for sure and our Quad Fuel Pump Hanger. How much of this did you buy from Titan? Cheers, Joe Link to comment Share on other sites More sharing options...
Terminator Posted June 11, 2008 Author Share Posted June 11, 2008 (edited) After a very a successful and exciting night, getting the car to fire and run, we wrapped up at about 2.00 this morning. Just had a call from one of the guys at the workshop to say my car was sat in a huge pool of purple oil. I have a 400 mile round trip to make today so can't go and look until about 21.00 this evening to be honest I don't want to look. If it is a big problem, I think I may call it a day and break it. Really pissed off right now. To make matters worse, we just found a huge crack in the RB25 tubular manifold. Edited June 14, 2008 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
bolarbag Posted June 11, 2008 Share Posted June 11, 2008 OOHH:( RB25 tubular manifold Which mani is it? Link to comment Share on other sites More sharing options...
Kopite Posted June 11, 2008 Share Posted June 11, 2008 Link to comment Share on other sites More sharing options...
Nic Posted June 11, 2008 Share Posted June 11, 2008 Hoping it's just something simple Phil Link to comment Share on other sites More sharing options...
Thorin Posted June 11, 2008 Share Posted June 11, 2008 Don't give up! Hope it's nothing serious. Link to comment Share on other sites More sharing options...
JamieP Posted June 11, 2008 Share Posted June 11, 2008 Same thing happened to me when we first fired my new toyota block up, turns out there is a little plug on inlet side of the block that we missed and i dumped £50 worth of oil on the floor:( hope yours is something simple aswell:) Link to comment Share on other sites More sharing options...
RobSheffield Posted June 11, 2008 Share Posted June 11, 2008 Which mani is it? Different car i suspect... Link to comment Share on other sites More sharing options...
bolarbag Posted June 11, 2008 Share Posted June 11, 2008 OOHH Quote: RB25 tubular manifold Which mani is it? Different car i suspect... I'd hope so;) Link to comment Share on other sites More sharing options...
Terminator Posted June 14, 2008 Author Share Posted June 14, 2008 (edited) All is well with the engine For a workshop prank, one of the guys in the workshop poured some fresh oil under the car . Only manage to get a few hours on the car over the past few evenings. Screamer pipe now fully plumbed in to the main system. Oil and water systems flushed and filled. New gasket and washers fitted to the cam covers, coil connector plugs changed for new ones. The system now sits in it's final position, at the lowest point it is only 4 cm lower than the chassis rails. The final elbow under the rear sub frame is no longer the lowest point on the car. This side view under the car shows clearly how high the system fits, beyond the newly undersealed rail. Edited September 4, 2011 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
Terminator Posted June 14, 2008 Author Share Posted June 14, 2008 OOHH:( Which mani is it? I was referring to the Greddy manifold on our 200sx/RB25,car. The split was at the joint where the collectors go from two to one just before the turbo flange. It is repaired now and back on the car. Link to comment Share on other sites More sharing options...
Nic Posted June 14, 2008 Share Posted June 14, 2008 Nice work Phil I really need to get my wastegate plumbed back into the exhaust too. Do you have a flexi joint on there? Link to comment Share on other sites More sharing options...
Terminator Posted June 16, 2008 Author Share Posted June 16, 2008 No flexi-joint it is just an unclamped sliding fit. Link to comment Share on other sites More sharing options...
MartinBattye Posted June 19, 2008 Share Posted June 19, 2008 hi Phil!! joined the board tonight!! this thread is very humbling!! thankyou! this car will be very subtle!!! Link to comment Share on other sites More sharing options...
Terminator Posted June 19, 2008 Author Share Posted June 19, 2008 (edited) Credit where it is due Martin. I am not sure the car will sound subtle unless we use the Burns bung. Visually there will be virtually no external change except the odd looking tail pipe and 295 rear tires, I just hope they are wide enough to handle the power. Last night we found that the IACV was not parking correctly making starting difficult. I found the spare IACV I have at home, so hopefully this one will get the idle under control tonight and make mapping the start up map a bit less of a challenge. Edited September 4, 2011 by Terminator Added information (see edit history) Link to comment Share on other sites More sharing options...
