Passenger interior grab handle
Ewen
Gently ease the rubber away from the top end, you'll find a steel clip. Prize the center away with a small screwdriver and push the handle in toward the pillar trim, it will just slide off. The plastic mounts then just unscrew. ;)
I spent a while messing about trying to get mine back on after the bottom clip was broken, put so much effort on it and though this has to be wrong!
Then after looking at it again and thinking this has to be wrong I tried it from the top and it all goes on and off prety easy lol
good luck
The handle slides on to some screwed in metal brackets.
Depending on which side has come off just push upwards for the top part of the handle and downwards for the bottom part (if that makes sense ?)
It is a weak part on the Supra and is porne to coming off, it will come off again if someone grabs it to get out of the car :)
