Using two operating systems over two hard-drives.
RedM
I have WinXP SP2 on one drive and I want to install a second drive and put a version of Linux on it.
Do the jumper settings need faffing with or has technology moved on?
How do I get it to offer a choice of OS? Is it a BIOS thing?
Will either OS be able to see the other and/or access the other drive?
If you already have WinXP or Windows Fista installed on a single drive you should be able to add another drive and install your fav distro, the boot manager (ie grub) should then provide options for your new linux install and windows on startup.
Once linux is loaded you should also be able to mount the windows drive but not the other way round ;)
Do I take that to mean that I could access info on the XP drive from the Linux drive but XP can't see or use the Linux drive?
If I don't mount the XP drive then are it's contents safe from anything that might get though the Linux firewall?
The missus has just okayed the purchase of a new HDD so it looks like I'm up all night downloading Ubuntu.:D
Yeah Linux will be able to read/write to your XP partition fine.
Windows can't access the Linux partition unless you install the driver I linked to.
