oilman Posted April 25, 2008 Share Posted April 25, 2008 At which temperature does an oil flow better? There is no temperature where oil suddenly starts to flow better. A 10W/40 for example will flow between -25C and 100C or more, but there is some difference in the rate of flow! (True viscosity at -25C is about 7000 Centistoke(cSt) units, dropping to 14 at 100C. ‘Viscosity’ is really just another name for ‘rate of flow’.) The correct question is at what (sump) temperature is an oil at a viscosity that suits a modern high-RPM engine? Present day designs are happy on an oil viscosity of 10 to 15 cSt. (But many are OK on less than 10.) 30cSt is too high at high RPM. It can lead to foaming, air entrainment and cavitation. Temp. for 30cSt (DegC)..........Temp. for 15cSt ............Temp. for 10cSt 5W/40.........71.............................90.................................117 10W/40.......70.............................99.................................118 10W/50.......80............................109................................130 10W/60.......89............................119................................142 As you will see from the above table a 5W/40 or a 10W/40 is perfectly adequate for all engines except those that run unusually high temperatures (120degC plus) Cheers The Opie Oils Team Quote Link to comment Share on other sites More sharing options...
AndyT Posted April 25, 2008 Share Posted April 25, 2008 Another info post saved. :)Thanks team. Quote Link to comment Share on other sites More sharing options...
SteveR Posted April 28, 2008 Share Posted April 28, 2008 Interesting Quote Link to comment Share on other sites More sharing options...
and1c Posted May 11, 2008 Share Posted May 11, 2008 Interesting. Thanks oilman Quote Link to comment Share on other sites More sharing options...
oilman Posted May 11, 2008 Author Share Posted May 11, 2008 Quote Link to comment Share on other sites More sharing options...
DannyB Posted May 11, 2008 Share Posted May 11, 2008 OILMAN do you frequent any other forums? Quote Link to comment Share on other sites More sharing options...
oilman Posted May 11, 2008 Author Share Posted May 11, 2008 About 400 Quote Link to comment Share on other sites More sharing options...
downimpact Posted May 11, 2008 Share Posted May 11, 2008 interesting, what temp does a standard TT run at once it's warmed up under normal conditions and under hard driving e.g. on track? Quote Link to comment Share on other sites More sharing options...
DannyB Posted May 11, 2008 Share Posted May 11, 2008 About 400 lol im sure ive seen some threads of yours on other sites im on, BMW5? and ISN? Quote Link to comment Share on other sites More sharing options...
Thorin Posted May 11, 2008 Share Posted May 11, 2008 I don't think there's a forum that he doesn't pimp his warez on. Quote Link to comment Share on other sites More sharing options...
