grahamc Posted April 24, 2008 Share Posted April 24, 2008 As above... starting a new project, looking for a rolling supra shell or a cheap NA Mileage, paintwork, etc not a probably, accident damaged would be considered as well... Link to comment Share on other sites More sharing options...
Homer Posted April 24, 2008 Share Posted April 24, 2008 A cheap NA is almost certainly going to be the most cost effective approach if you're going for anything other than a ground up rebuild (i.e. every part replaced). Keep an eye on the auctions, tired NA auto's can be had for not much more than £1500 if you are lucky. IMO it's not worth getting a shell as the time and cost of rebuilding it could easily pass the cost of a complete NA. Are you going to hint what your plans are? It might be easier to give some recommendations with a rough idea of what your needs. Link to comment Share on other sites More sharing options...
grahamc Posted April 24, 2008 Author Share Posted April 24, 2008 A cheap NA is almost certainly going to be the most cost effective approach if you're going for anything other than a ground up rebuild (i.e. every part replaced). Keep an eye on the auctions, tired NA auto's can be had for not much more than £1500 if you are lucky. IMO it's not worth getting a shell as the time and cost of rebuilding it could easily pass the cost of a complete NA. Are you going to hint what your plans are? It might be easier to give some recommendations with a rough idea of what your needs. Do agree with you... I want to use the car for mostly drag racing, but more as something to learn with... Eventually building up the engine, etc. With a shell I might be tempted to go for a little too much power a little too quickly But still considering all my options! EDIT: Jezz has a nice looking shell that I am considering.... would be good, if I knew what I wanted and not as above.... Link to comment Share on other sites More sharing options...
Homer Posted April 24, 2008 Share Posted April 24, 2008 Are you planning on keeping it 2JZ? If not then a working rolling shell from Jez would be ideal, if not and you want a fast drag car a cheap TT auto would surely be the most cost effective start point. They can be had for peanuts if you put a lot of work/time into a search. Link to comment Share on other sites More sharing options...
grahamc Posted April 24, 2008 Author Share Posted April 24, 2008 Are you planning on keeping it 2JZ? If not then a working rolling shell from Jez would be ideal, if not and you want a fast drag car a cheap TT auto would surely be the most cost effective start point. They can be had for peanuts if you put a lot of work/time into a search. Still undecided on the 2JZ... it is big and heavy. However its not a bad place to start from. I was honestly think about starting with a NA and then deciding on the engine in the not too distant future. Times are for me only in the beginning. But yes, if I knew exactly what I wanted, then the shell would be best! However I am still undecided on some things, which is making me hesitate. Link to comment Share on other sites More sharing options...
Dr S Posted April 25, 2008 Share Posted April 25, 2008 ...a working rolling shell from Jez would be ideal... Me be stoopid, can anyone gimme a link to Jez? I need a rolling UK-shell, wo. engine, gearbox, interoir ang other bits & pieces... Link to comment Share on other sites More sharing options...
Lebsteif Posted April 25, 2008 Share Posted April 25, 2008 Me be stoopid, can anyone gimme a link to Jez? I need a rolling UK-shell, wo. engine, gearbox, interoir ang other bits & pieces... Here you go: http://www.mkivsupra.net/vbb/forumdisplay.php?f=131 Link to comment Share on other sites More sharing options...
grahamc Posted May 1, 2008 Author Share Posted May 1, 2008 Still looking, but NA only... not a shell anymore ( would spend too much money on a shell ) Link to comment Share on other sites More sharing options...
Tee from China Posted May 10, 2008 Share Posted May 10, 2008 This any good? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110246393522 Link to comment Share on other sites More sharing options...
JamieP Posted May 10, 2008 Share Posted May 10, 2008 This any good? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110246393522 Confusing advert, i bet that gets removed. Link to comment Share on other sites More sharing options...
grahamc Posted May 10, 2008 Author Share Posted May 10, 2008 Confusing advert, i bet that gets removed. have to agree... Link to comment Share on other sites More sharing options...
Mariusz Posted May 10, 2008 Share Posted May 10, 2008 There is a n/a silver on autotrader 1450... Link to comment Share on other sites More sharing options...
