Jim_1979 Posted April 24, 2008 Share Posted April 24, 2008 If I shut my drivers door it doesn't shut properly unless I slam it. The glass window seems to hit off the part above the door (the rain drip thing?). The only way I can get it to shut is to either slam it, shut it by pushing the glass, or put the window down - shut the door then put it back up. (from the inside) Anyone experienced this before? Any ideas? thanks Quote Link to comment Share on other sites More sharing options...
jacko Posted April 24, 2008 Share Posted April 24, 2008 i have exactly the same problem, still trying to find out what do to lol Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 24, 2008 Author Share Posted April 24, 2008 lol... excellent. Two of us! Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 24, 2008 Share Posted April 24, 2008 my passenger door doesnt seem to quite shut right. its difficult to close sometimes and when its closed properly it seems to not be lined up right and seems to stick out a little. Ive been meening to look at it properly but have never had chance. Quote Link to comment Share on other sites More sharing options...
merckx Posted April 24, 2008 Share Posted April 24, 2008 If you remove the door card you'll see an adjuster at the bottom, this will move the top of the window in or out as required. I can't remember exactly what the adjuster looks like but there's a plastic collar of some sort fitted over it. Infact you can adjust the glass in every direction with the other fasteners. Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 24, 2008 Author Share Posted April 24, 2008 So what way would it need to be moved? Inwards? Quote Link to comment Share on other sites More sharing options...
Ewen Posted April 24, 2008 Share Posted April 24, 2008 So what way would it need to be moved? Inwards? Tightening the bottom adjuster clockwise will move the top edge of the glass inwards, and vice versa. Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 24, 2008 Author Share Posted April 24, 2008 Excellent... I'll have a good look when I have the time. Anyone got pics of exactly where the adjuster is? thanks Quote Link to comment Share on other sites More sharing options...
Homer Posted April 24, 2008 Share Posted April 24, 2008 Excellent... I'll have a good look when I have the time. Anyone got pics of exactly where the adjuster is? thanks If no one can supply one in the mean time I can get you a pic tomorrow. Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 24, 2008 Author Share Posted April 24, 2008 cheers Quote Link to comment Share on other sites More sharing options...
Ewen Posted April 24, 2008 Share Posted April 24, 2008 Excellent... I'll have a good look when I have the time. Anyone got pics of exactly where the adjuster is? thanks Its half way along the inside bottom edge of the door...at the end of a vertical pressed metal spar thats part of the window carrier. It has a white plastic collar, Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 28, 2008 Author Share Posted April 28, 2008 Any pics guys? Quote Link to comment Share on other sites More sharing options...
merckx Posted April 28, 2008 Share Posted April 28, 2008 Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted April 28, 2008 Author Share Posted April 28, 2008 The bit in the middle of the two white bits? Quote Link to comment Share on other sites More sharing options...
merckx Posted April 28, 2008 Share Posted April 28, 2008 The bit in the middle of the two white bits? Yes, as far as I remember the bracket is there to hold it in the correct place after adjustment, I think there's a plastic collar in the middle. You can get get a fair amount of adjustment so you'll definatley know when you've figured out how it works. Quote Link to comment Share on other sites More sharing options...
Dragonlady Posted April 29, 2008 Share Posted April 29, 2008 might need to adjust mine as it leaks water above 65mph, get a soggy arm. Quote Link to comment Share on other sites More sharing options...
Guest bonomitch Posted January 7, 2009 Share Posted January 7, 2009 If you remove the door card you'll see an adjuster at the bottom, this will move the top of the window in or out as required. I know this post is really old - but I have this same problem and it looks like it should fix it too - so thanks! Quote Link to comment Share on other sites More sharing options...
Big Ian Posted January 7, 2009 Share Posted January 7, 2009 I know this post is really old - but I have this same problem and it looks like it should fix it too - so thanks! Ditto! and ive already had to replace that adjuster look's like i'll have the door card off again tomorrow Quote Link to comment Share on other sites More sharing options...
