lockys96 Posted April 24, 2008 Share Posted April 24, 2008 actually got an email from phoenix power japan with specs on the internals of my engine. im not sure what 8.8: means though? It is communication about the SW20 engine inside. Original 2,200cc kit 87mm forging piston H section connecting rod .91mm stroke crankshaft compression ratio 8.8: It is one head port processing / 272 valve spring change .272 cam (an in side) cam (Eki side) cam lift 10.3mm others 650HP correspondence engines. I make wish. Quote Link to comment Share on other sites More sharing options...
tDR Posted April 24, 2008 Share Posted April 24, 2008 8.8:1 compression ratio it means - raised from the standard 8.5:1 compression ratio. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
michael Posted April 24, 2008 Share Posted April 24, 2008 8.8:1 compression ratio... it means your compression ratio is 8.8:1 Edit, too slow Quote Link to comment Share on other sites More sharing options...
lockys96 Posted April 24, 2008 Author Share Posted April 24, 2008 ah, cool. must go see what that means for potential Quote Link to comment Share on other sites More sharing options...
