Lebsteif Posted August 4, 2008 Author Share Posted August 4, 2008 (edited) Good news, car is almost back on the road. Only need the clutch and we are off again. With the correct partnumbers it is an easy conversion and doesn;t take long to do. The only problem is the waiting time for certain parts. Transmission Shift Fork P/N: 31204-14031 Shifter housing part# 33521-24040 Control Shift Lever part# 33570-24010 1JZ-GTE Bell housing for R154 Transmission P/N: 31111-14110 MK3 Slave Cylinder P/N: 31470-14050 Rear Tail Shaft Oil Seal P/N: 90311-40001 Flywheel bolts P/N: 90910-02103 (8 Of them) Clutch release hub bearing P/N: 90363-45012 or 31231-14040 throw out (pilot bearing) P/N: 90363-12002-77 It's almost like a LEGO kit, i'm expecting the photo's soon from the garage. Will make the write up and hopefully i can drive soon again Edited August 4, 2008 by Lebsteif (see edit history) Quote Link to comment Share on other sites More sharing options...
miko_supra Posted August 24, 2008 Share Posted August 24, 2008 Good news, car is almost back on the road. Only need the clutch and we are off again. With the correct partnumbers it is an easy conversion and doesn;t take long to do. The only problem is the waiting time for certain parts. Transmission Shift Fork P/N: 31204-14031 Shifter housing part# 33521-24040 Control Shift Lever part# 33570-24010 1JZ-GTE Bell housing for R154 Transmission P/N: 31111-14110 MK3 Slave Cylinder P/N: 31470-14050 Rear Tail Shaft Oil Seal P/N: 90311-40001 Flywheel bolts P/N: 90910-02103 (8 Of them) Clutch release hub bearing P/N: 90363-45012 or 31231-14040 throw out (pilot bearing) P/N: 90363-12002-77 It's almost like a LEGO kit, i'm expecting the photo's soon from the garage. Will make the write up and hopefully i can drive soon again Cheers for this. I may need to do this in the near future...What is it like cost wise? Quote Link to comment Share on other sites More sharing options...
DAT Inter Posted September 18, 2008 Share Posted September 18, 2008 Bump. Any update on this? How much did it cost? Quote Link to comment Share on other sites More sharing options...
b.weeks Posted September 18, 2008 Share Posted September 18, 2008 Where did you get this done? Quote Link to comment Share on other sites More sharing options...
Guest majic79 Posted September 18, 2008 Share Posted September 18, 2008 I've done the conversion for my MKIII Supra, it cost me approx £800 for the parts, one thing that's missing off that list is the 1JZ flywheel, does the 2JZ-GE fly fit? (I know the 2JZ-GTE one doesn't!) 2nd gear, must have been a good launch! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 18, 2008 Share Posted September 18, 2008 Welcome Chris Not sure about the flywheel though Quote Link to comment Share on other sites More sharing options...
Guest majic79 Posted September 18, 2008 Share Posted September 18, 2008 Oh oh, someone who knows me.... hope it's not that dodgy geezer that blew his soarer up..... Quote Link to comment Share on other sites More sharing options...
Guest 4door Posted September 21, 2008 Share Posted September 21, 2008 1jz flywheel 7mgte clutch Quote Link to comment Share on other sites More sharing options...
