noise from drive shaft or gear box
Guest teknosteve
Guest teknosteve
Hi
Can anyone help i have a supra rz twin turbo 0.6bar jdm 6speed
There is a rattle coming from what i think is the drive shaft. when you tap the throttle it sounds like the drive shaft is wobbling back and forth. it rattles my you hit bumps as well. i jacked up the car and when you move the rear wheel forward about 4inchs then back and so on it rattles around where the drive shaft come out of the gearbox. Sound like two pieces of steel hitting of each other.
if anyone has had this problem or know what is is please help.
teknosteve rz
  • 3 weeks later...
Hard to shift or will not shift
1. Synchronizer ring (Worn or damaged)
2. Shift key spring (Damaged)
Jumps out of gear
1. Locking ball spring (Damaged)
2. Shift fork (Worn)
3. Gear (Worn or damaged)
4. Bearing (Worn or damaged)
Guest teknosteve
easy to shift
popped out of 1st maybe 5times in 7-8months
its not make any problems just if you tap the throttle back and forth you can hear it rattle
but now when you hit bumps on the road you can hear it rattle really bad it stops if you put your foot on the brake (in gear and neutral) or could this be 2 different rattles
Edited by teknosteve (see edit history)
