Front indicators - how to get off?
razza
I've got a dilemma...changing my sidelights and obviously didn't put the bulb in tight enough, as I put it back in the thing fell out:rolleyes: It's now rattling round in the lens.
What's the easier way to get the lens front or the indicator unit off?
Had a quick look and it seems held on by 3 bolts, 2 at the back and one at the side? Not sure about the side one as can't see, do I just undo the two rear ones and then slide it out? Or is there a nut under the bumper that I have to take the undertray off for?
Thought that was some kind of indicator porn.
I know, i know i'm leaving myself open for "why did you click it then" ;)
Worth it!
Think you're in the wrong section then if that's what you're after;):p
On your tod tonight then and after some relief? lol!!
sounds like a load of hassle to me, arse!!
Ok, how do you get the headlight out, their UK's if that makes any difference?
How long do you reckon it would take for a first timer?
It's very easy, 2 minute job max ;) Just undo the 3 light harneses, undo the 2 nuts and 1 bolt securing the headlight and *carefully* remove the light. If you're in the area drop by and I'll show you how.
job done, tried doing this tonight and didn't have a spanner small enough for one of the nuts, however handy having small wrists as manged to get a pair of tweezers, fit my hand between the bottom of the headlight and reached into the back of it to pull the bulb out, sidelight now fixed:D
