bignum Posted April 23, 2008 Share Posted April 23, 2008 Ive just fitted my injectors and wanted to check for leaks before i fit the plenum and everything back on, so i switched the ignition on and linked +b and fp in the diagnostic port and i`m getting sweet fa/ the pump isnt operating, is there anything i have to do differently, cheers in advance. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2008 Share Posted April 23, 2008 Turn the ignition on? Sorry, but it may not be obvious.. Link to comment Share on other sites More sharing options...
bignum Posted April 24, 2008 Author Share Posted April 24, 2008 Turn the ignition on? Sorry, but it may not be obvious.. Done that, any other ideas before i bypass the fuel relay to test Link to comment Share on other sites More sharing options...
Ryan.G Posted April 24, 2008 Share Posted April 24, 2008 Should defiantly work by just turning on the ignition, disabling alarm and then bridging those pins. If the fuel pump connector in the boot connected? Also check to see if there is 12v at the B+ Pin. If not then the main relay is not opening Ryan Link to comment Share on other sites More sharing options...
bignum Posted April 24, 2008 Author Share Posted April 24, 2008 Ryan you`re a genius, forgot to do the immobiliser,,i owe you 1, oh and i have a leak on 1, good job i checked it. Link to comment Share on other sites More sharing options...
