Hks F-con Pro Gold
Chief Quimby
My supra from JM-import is on the way, he will map it before i get it...
But i would like to map it myself here in denmark, when i upgrade some stuff...
But is there anyway i can get the software, and use it witout having that doungle(thinks it is called), to put in USP port in computer....
I am willing to pay some money for the software..
Thanks guys
Quimby
software may be included, but the add doesn't mention the dongle. And I hightly doubt that there would be one available as they are only handed out by HKS themselves to their Pro Dealers.
But in denmark there only 2 possible mappers: k-power and lksport
btw. Tillykke med den ;-)
The doungle is on the pic, but must check it out before buying it...
Trust me, forget the ECU in the car, unles somewher over there is a respected tuner of the HKS ECU. If it's heavily modded, or going to be, find a good local tuner and bite the bullet (spend the money in English) and fit an ECU they are familiar with, and fit that, long term it will be cheaper and probably save the engine. How are the local tuners with the AEM ecus, or a MOTEC?
The dongle looks like a copy and i expect will only work on that Fcon or other fcon's running the same firmware. When you become a HKS power writer you gain access to the files to update the dongle for new firmware upgrades etc.
Also using a copy of the software and dongle will most likely net you in abit of trouble with HKS if you are not careful.
They are very selective to who gets the software
Ryan
