Sock Fuel Pressure Regulator adjustable?
randy
Originally posted by randy
Is there a way to increase the fuel pressure on our jap spec stock fuel system? Is the stock fuel Pressure Regulator adjustable and where exactly is it located?:)
I don't beleive it is adjustable as I had an adjustable one fitted on my car ..... I don't know where the original one was located regrettably.
The stock FPR is located on the fuel rail, front of the car end (just above injector #1).
The fuel rail nestles between the intake manifold and the cylinder head. It's a long narrow metal thingy with six fuel injectors stuffed in it.
It's attached by two bolts, has a fuel hose going in the side, and a 1/4" vacuum hose going in the round UFO-shaped bit.
It's not adjustable.
The question is - why do you want to adjust it? :)
-Ian
-Ian
So there is no way I could increase the fuel going through! Basically I feel I am running lean at a specific RPM. I am planning to get the Apex S- AFC and will be upgrading my fuel pump to a bosch 223 litre/hr capacity.
