Most likely the dumbest question in the supra forums history but...
Guest FKADizzmystar
FCD is an electronic device that overrides the high boost fuel cut function of your vehicle's ECU. It broadens the area of high boost which will allow the vehicle to obtain much higher boost settings, giving a increase in performance as well as faster response.
boost controller raises the boost pressure for your turbos..
Guest FKADizzmystar
basically what iam doing is puting a full exhaust system on, Turbo back and ppl have been saying in need a boost cut controller to bring the boost down when i put the exhaust on, so iam finding out about them.
Guest FKADizzmystar
what would be the best Turbo Back Exhaust system for a 1994 j-spec Auto. and not overly loud either. ??
Define "best"
Define "overly loud"
how many restrictor rings
One
and that with a BCC aswell
Depends on the RR.
HKS Titanium?
When you decat you need a restrictor ring in the exhaust (probably a 1bar RR), then get a boost controller to turn the boost up when you want it up, also get a fuel cut defender (or boost cut controller - same thing) so that the ECU doesn't cut the fuel when you're running on the boost controller controlled higher than normal boost setting. :D
