Fuel Pressure Regulator
Markie
I have been reading some threads about the FPR's and just wondered if this this would do the same job..
Hopefully the engineers here will be able to crack the code in which the description of this is written :blink:
(Picture Attached)
The Aeromotive A1000-6 Injected Bypass Regulator was developed for high horsepower EFI applications. Compatible with the Aeromotive A1000 Fuel Pump, this regulator is a cousin to our widely-used A1000 Injected Bypass Regulator, delivering performance, long-life, and reliable operation.
Base pressure (vacuum/boost disconnected) is adjustable from 30 to 70 PSI. Alcohol compatible. Provides two -6 AN inlet ports and one -6 AN return port. Fuel pressure will rise on a 1:1 ratio when referencing boost. 1/8" NPT gauge port. Beautifully finished with type II bright red and clear anodized coatings.
Applications: For high horsepower EFI applications where -6 AN fuel lines are used for supply and return.
