oil catch tank
supra_si
LOL there is no stock catch tank. The charcoal canister is for removing petrol vapours evaporating from the fuel tank - it has three connections, because it uses boost pressure to flush the vapours through.
  • 3 weeks later...
So what about the PHR breather kit then. It doesnt go back to the intake, its to atmosphere?
I get confused by these things...especially when the crankcase pressure comes into play. Cue some technical bods to explain all! (please) :D
Cheers
G
Cheers
G
Have a read about -> breather systems
Does anyone happen to know the bore size of the stock breather hose? I want to buy some Samco flex-hose like the pictures in posts 8 and 10.
Not sure if this is what you are looking for but the recomended size for TT's is 15mm iirc.
