possible sensor problem, help
TrevS
Hi there
I have just noticed a problem that has just started happening with my car. When i go above 60mph the exclamation warning light and the door, boot, bonnet open light flashes at the same time.
I pulled over twice to check the boot was closed properly, doors and the bonnet. But its still doing it. I also tried test the doors etc by closing them all and then trying to pull on the doors, bonnet and boot one by one to see if I could narrow down which of the 4 sensors could be causing the problem but it didn't flash up.
Anyone have any ideas? At the moment I can only think its the bonnet and that as the wind force increases above 60 the air could be pushing the bonnet up from the underside causing it to set the sensor off.
Any help would be great
Thanks
mine is a 96 n/a facelift and when I was sat in the car with it running and pulled the bonnet release the door open light flashed on.
I tryed it again today and it didn't work. Then I started the car on so it was running again and tried it and the flashed up again. So seems only to work when the car is running I think but may be wrong.
