Why no increase in power with increase in boost??
tucky40
Hi all,
Just had the car mapped today (thankyou Matt and Ryan) in TTC with an AEM.
Produced very nice figures at 0.8bar but apparently no real power was gained by increasing the boost above 0.8bar.
This is strange as there was a noticable gain between 0.8bar and 1.2bar in sequential.
Can anyone think why this would be?? could it be that my exhaust is too restrictive, I have the blitz nur spec RX, maybe the restrictor ring, boost leak or something else??
Any suggestions welcome, havent had a proper chance to discuss with Matt or Ryan yet as im away but the more advice the better.
Thanks, Ben.
Thanks for the rapid reply Matt,
I'll keep my fingers crossed that its just the restrictor ring. It would definately be the cheaper option! Look forward to getting the car on tues.:eyebrows:
No problem matey, certainly a stout power level for 0.8bar !
It may be that the cams have affected how and where in the RPM range its making boost, so it is possible that the RR is now too restrictive.
Yeah could be mate :)
Lovely Car Mate.
The exhaust system is definatly the issue. As with more boost the car was alot more limited to ignition timing meaning that the cylinder temps were getting hot causing instantaneous explosives. Due to this, the timing was alot less in the higher boost area's which will cause no gain in power.
I knew the restrictor ring would be an issue straight away though as in TTC mode with no duty on the solenoid it only hit 10psi. If it was my car i would keep your exhaust but open the RR up abit.
Ryan
just a question mate, why go to all the expense of an AEM ecu to control stock twins :blink:
I initially went down the Emanage Ultimate route for cost reasons really mate and i thought a standalone was overkill.
With the more aggressive cams i had a pretty lumpy idle due to the fact that the piggy back wasnt controlling fuelling in closed loop. The stoich afr of 14.8 to which the stock ecu was pulling the fuelling on idle was cuasing a lumpy idle.
Being a perfectionist this was a little annoying and i was told that with a standalone that the afr at idle can be leaned out a little towards 13s and this would make for a nicer idle.
Also I had decided I wanted the car mapped in TTC, this is best done on a dyno so that timing can be adjusted etc. Ian C doesnt do dynos so my car would never have been mapped as accurately.
I hope it also makes the car much more attractive when selling and also futureproofs the car if i decide to go sinlge.
It was a big expence but I decided to pay the extra and get a better ecu, also you get knock protection with the Aem which could save my engine if something went wrong. I can now sell my AVCR boost controller as the Aem is doing bosst control.
looks nice:eyebrows: good output on stock twins, what other mods have you got bar the cams and FMIC?
Hi mate,
I have double de cat, Blitz nur spec RX, better plugs, FMIC, 650cc injectors and AEM. Thats it.
Again I went for 650cc injectors due to cheekymonkeys experience with TTC, alot more injector duty than expected was needed when he initially had his car mapped.
I wanted to build in a large element of safety and again futureproof the car to accomodate a small single in the future.
Maybe it wasnt the cams Tricky-Ricky but the fuelling never seemed happy in closed loop. Another reason for taking the EMU and stock ecu out of the equation.
The lift on the jun cams was also a fair bit more than the hks ones.
Tucky has sent me his EMU to try in my own car, as it certainly displayed some spurious behaviour in his. I'll see if it acts up in mine, if it does it's the first one I've heard of going doolally but hey, it's electronics and cars ;) If it doesn't then I've got no idea what was wrong as the datalogs I got off Ben were bizarre yet his car is (thankfully) running lovely now with the AEM.
It certainly wasn't the usual issues of O2 sensor, MAP sensor, water temp stuff et al...
A disappointing and frustrating episode for a thoroughly nice chap, glad it's OK now :) Get your nail file on that thar restrictor ring ;)
-Ian
