Where can i get a A-Pillar Pod ?
Pred
Hi ya Pred,I could make you one if you like and cover it in leather or alcantara ,is it a single pod you would like or double or triple the choice is yours ,i would have to sorce the A pilar plastic from a breakers yard which wouldnt be hard and i can make it from there on and posting not a problem give me a PM if your interested .
i search an pod for 2 52mm gauges
If you speak to Gaz at Envy I'm sure he will get it drilled to suit 2 x 52mm gauges :)
The Envy one I found was the best available when I was looking a year ago, as it replaces all the trim including up and over the roof. Very nice bit of kit :)
What sort of price would that be?
I have an Envy one and it's certainly the best of the bunch as far as looks go, I just think it misses a trick on the fixing side of things so your option would solve that.
