Guest Suprafly Posted April 16, 2008 Share Posted April 16, 2008 Right, I'm replacing my water pump and timing / aux belt, now I have removed the crank aux pulley and I think it may be knackered. If you hold the pulley wheel in your hand and grip it, then grip the wheel on which the belt goes round, should you be able to turn it? It turns quite freely, is this buggered and do I need a new one? Also are the tt crank pulleys the same as the n/a? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 16, 2008 Share Posted April 16, 2008 If you hold the pulley wheel in your hand and grip it, then grip the wheel on which the belt goes round, should you be able to turn it? Huh? "Hold the pulley wheel then hold the wheel the belt goes round"? Isn't that the same part? You're not making yourself very clear mate - not to me anyway. The outer part of the crank pulley should not move independently to the centre part of it - if that's what you're getting at? Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted April 16, 2008 Share Posted April 16, 2008 Then it's shot because it does move independantly against the outer bit. Do you know if the TT pulley is the same as the n/a? Quote Link to comment Share on other sites More sharing options...
