Guest CoolsBlue Posted April 15, 2008 Share Posted April 15, 2008 found some alloys but will they fit? 18" rims Size: 9.5 x 18 for the FRONT & REARS PCD: 114 ET: 42 tyres 265/35 W/18 cheers, Kevin Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted April 15, 2008 Share Posted April 15, 2008 Yes, they will fit. Offset is ok, but the wheels are too wide for the front and you'll probably end up with bad tram lining. Fronts should be 8.5 wide with 235 width tyres... Some people do run 9.5s on the front but i'm not sure what the handling is like & they might catch the arch.. You might get away with fitting 235/245 tyres to the front wheels. Quote Link to comment Share on other sites More sharing options...
merckx Posted April 15, 2008 Share Posted April 15, 2008 Quote Link to comment Share on other sites More sharing options...
