mintedm Posted April 14, 2008 Share Posted April 14, 2008 tried searching through treads couldnt find anything running bad even when idling, first thought was to change plugs! done this no change, so changed the leads! no change! tried the old paperclip idea but this didnt seem to come up with anything didnt even flash! any ideas appreciated!!!! Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted April 14, 2008 Share Posted April 14, 2008 Has it slowly got to this stage or just all of a sudden? N/A or TT? Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 Has it slowly got to this stage or just all of a sudden? N/A or TT? sorry forgot to mention this N/A mate, yeh just all of a sudden, was running like a dream one of the boys in work even commented on how quiet it ran.thats what makes me think its a sensor Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted April 14, 2008 Share Posted April 14, 2008 the paper clip thing... are you sure you did it right because if there are no error codes stored the light should still flash, just not in a number sequence Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 the paper clip thing... are you sure you did it right because if there are no error codes stored the light should still flash, just not in a number sequence yes mate thought that myself, read the tread and put it in the ones it said and turned key but no flash Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 14, 2008 Share Posted April 14, 2008 Have recently washed the engine or gotten lots of water near it? Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 Have recently washed the engine or gotten lots of water near it? only thing could think of is the carbon bonnet and water coming into the vents it gets a bit wet up this next of the woods! damp electrics? Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 14, 2008 Share Posted April 14, 2008 only thing could think of is the carbon bonnet and water coming into the vents it gets a bit wet up this next of the woods! damp electrics? Take off the intake body... get an airline in there and blow the water out It has a habit of going between the cams and sitting there...right pain in the........ Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 Take off the intake body... get an airline in there and blow the water out It has a habit of going between the cams and sitting there...right pain in the........ what split where it goes over the the spark plugs and blow in there? surely it should have evaporated by now the cars been sitting off road for a week Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 14, 2008 Share Posted April 14, 2008 what split where it goes over the the spark plugs and blow in there? surely it should have evaporated by now the cars been sitting off road for a week Between the cam covers, there is a plate which the plugs go through, water once it gets down in that gulley it is notoriously bad for misfiring (speaking from experience twice), causes it to missfire and give it a boxy sound. Doesn't evaporate out, especially in this cold. Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 good stuff mate ill try that tomorrow night , good to get another suggestion!!! Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 14, 2008 Share Posted April 14, 2008 good stuff mate ill try that tomorrow night , good to get another suggestion!!! No prob... if you aren't seeing any lights are you sure your dash lights work.. http://www.mkivsupra.net/vbb/showthread.php?t=115407 Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 14, 2008 Author Share Posted April 14, 2008 No prob... if you aren't seeing any lights are you sure your dash lights work.. http://www.mkivsupra.net/vbb/showthread.php?t=115407 yeh pretty sure they do ill check this out tomorrow Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 15, 2008 Author Share Posted April 15, 2008 Between the cam covers, there is a plate which the plugs go through, water once it gets down in that gulley it is notoriously bad for misfiring (speaking from experience twice), causes it to missfire and give it a boxy sound. Doesn't evaporate out, especially in this cold. right tried this and it was soaking end 2 plugs dried these out , built it back up and still running same, took off distributer cap and very top of rotor arm broke off not the tip but the very top off it. would this make a diffence? Quote Link to comment Share on other sites More sharing options...
mintedm Posted April 16, 2008 Author Share Posted April 16, 2008 bump Quote Link to comment Share on other sites More sharing options...
Tom Posted April 17, 2008 Share Posted April 17, 2008 check for air leaks, is the car hunting on idle? if there's no air leak then i'd be looking at cleaning/replacing the o2 sensors, i've pretty sure the n/a has 2. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted April 17, 2008 Share Posted April 17, 2008 Yes it does have two. Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 17, 2008 Share Posted April 17, 2008 right tried this and it was soaking end 2 plugs dried these out , built it back up and still running same, took off distributer cap and very top of rotor arm broke off not the tip but the very top off it. would this make a diffence? Make sure you dry it out completely, you might need to check you haven't ended up with damp HT leads as well. Replace the rotor arm personally.... Quote Link to comment Share on other sites More sharing options...
mintedm Posted May 28, 2008 Author Share Posted May 28, 2008 check for air leaks, is the car hunting on idle? if there's no air leak then i'd be looking at cleaning/replacing the o2 sensors, i've pretty sure the n/a has 2. ill try cleaning these then!! replaced cap and rotor arm, with no luck still lol Quote Link to comment Share on other sites More sharing options...
mintedm Posted May 28, 2008 Author Share Posted May 28, 2008 has anyone got pics of these so i know what im removing Quote Link to comment Share on other sites More sharing options...
Dazzi Posted May 28, 2008 Share Posted May 28, 2008 has anyone got pics of these so i know what im removing pics of the 02 sensors? Quote Link to comment Share on other sites More sharing options...
mintedm Posted May 28, 2008 Author Share Posted May 28, 2008 aye Quote Link to comment Share on other sites More sharing options...
Dazzi Posted May 28, 2008 Share Posted May 28, 2008 aye If you stand on the drivers side they can be found under a heat shield. I managed to change mine once without removing this. Quote Link to comment Share on other sites More sharing options...
mintedm Posted May 28, 2008 Author Share Posted May 28, 2008 If you stand on the drivers side they can be found under a heat shield. I managed to change mine once without removing this. http://i139.photobucket.com/albums/q305/Ripon-Racer/RIMG0004-1.jpg http://i139.photobucket.com/albums/q305/Ripon-Racer/RIMG0001-1.jpg and these can be taken out and cleaned? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted May 28, 2008 Share Posted May 28, 2008 and these can be taken out and cleaned? A temporary measure is to take them out and leave them in lemons. The acid will dissolve the carbon. When I did this it lasted a few weeks. Give it a go, if your car runs better you will know what the problem is Quote Link to comment Share on other sites More sharing options...
