UK TT cams in Jap TT engine...
Jim_1979
The exhaust cam is the same on both models, the UK spec has longer duration and higher lift intake cam
J-spec
Intake Duration 224°
Intake Camshaft lift 7.88mm
Intake valve diameter 33.5mm
Intake Valve timing - Opening 3° BTDC
Intake Valve timing - Closing 50° ABDC
Exhaust Duration 233°
Exhaust Camshaft lift 8.4mm
Exhaust valve diameter 29mm
Exhaust Valve timing - Opening 52° BBDC
Exhaust Valve timing - Closing 4° ATDC
UK Spec
Intake Duration 233°
Intake Camshaft lift 8.25mm
  • 2 years later...
  Jim_1979 said:
Any benefit to doing this?
Also, would the car need properly mapped to run these?
Exactly my question????
I have built an engine using these cams, can they be safely run with the std jap spec ECU or do you swap in 550cc UK injectors and ECU? and if you swap in the ecu does it run without an AFM and on the JAP loom????
i would say that the very modest power increase of about 10 hp you get from this cam the stock injectors would be able to cope, you really would have to get a dyno run to make sure the fueling is ok, an old signal fudger like an SAFC would be ideal for this basic mod
  • 1 month later...
These are the specs given for the J spec cams given on
http://mkiv.supras.org.nz/specs.htm
Intake valve dia. 33.5 mm
Intake valve lift 7.8 mm
Exhaust valve dia. 29.0 mm
Exhaust valve lift 8.4 mm
Intake opening 3 deg BTDC - 41 deg ABDC
Exhaust opening 52 deg BBDC - 4 deg ATDC
Very different to those posted by Nic.
Which figures are correct?
Has anyone ever considered fitting an N/A inlet cam to their T.T.
Intake valve lift 8.3 mm
Intake opening 3 deg BTDC - 52 deg ABDC
Edited by David P (see edit history)
No disrespect, Nic, but those numbers don't make sense. The durations and valve opening / closing timings don't match. Assuming the valve opening / closing events are correct I've calculated the proper durations. See my notes in your quote. This would mean that the durations for UK and J-spec were the same, but with different lifts. I suspect that the info on the website is wrong.
J-spec
Intake Duration 224° - Should be 233°
Exhaust Duration 233° - Should be 236°
UK Spec
Intake Duration 233° - Correct
Edited by Digsy (see edit history)
You're the expert Darren :) I just copied and pasted the info from http://www.turbosupras.com/pages/en/pages/specifications/JZA80/jza80.htm
Do the figures from http://mkiv.supras.org.nz/specs.htm that David posted earlier look correct?
Its difficult to tell as they only quote the valve open / close events. The durations from the NZ site would be:
TT intake: 224deg x 7.8 lift
TT exhaust: 236deg x 8.4 lift
NA intake: 235deg x 8.3 lift
NA exhaust: 236deg x 8.4 lift
Looks like the exhaust cam is common and the intake valve closing figure might be wrong in the data you posted, as the duration and intake valve opening figures match.
Of course the NZ site doesn't say if their data is J-spec, Uk or Federal.
i have uk cams on my j spec but not pushing it too hard. im going to replace them with j specs as im only staying bpu and not mapping. the UK's would be great for someone thats going to remap with larger injectors. say 550's or larger or maybe even doing a hybrid turbo conversion.
No need to change the exhaust cam as they are the same.
But looks like an N/A inlet cam could give gains, maybe Digsy could comment.
Neither site gives enough information to meaningfully compare the cams. Duration at what lift is the missing link. Without that it's all speculative. i have posted this before, but this is what a proper cam spec sheet looks like. If anyone wants to pay I can measure the cams on a Cam Doctor type machine.
CAM PRO PLUS Cam Card Report 11:42:59 08/10/2010
Spec. Value
File x:\Chris Wilson Direct acting mechanical profiles\D300-D399\D361.CPP
Lobes I1
Lobe Separation ----- Cam Deg.
Checking Height 0.010 Inch
Valve Overlap ----- Crank Deg.
Intake Exhaust
Centerline 106.0 ATDC
Open 44.8 BTDC
Close 76.9 ABDC
Duration 301.8 Crank Deg.
Area 37.12 Inch Deg.
Lash 0.0250 Inch
Rocker Ratio 1.00
Peak Cam Lift 0.43405 Inch
Peak Valve Lift 0.40905 Inch
Lift @ TDC 0.1363 Inch
Spec. Value
Checking Height 0.039 Inch
Intake Exhaust
Open 21.3 BTDC
Close 52.2 ABDC
Duration 253.5 Crank Deg.
Area 36.69 Inch Deg.
Lash 0.0250 Inch
Rocker Ratio 1.00
Well, to be fair a lot of the information is there but you just have to work it out from the figures given, but I agree the key thing that is missing is the time x area figure.
Spec. Value
Lobes I1
Intake Exhaust
Centerline 106.0 ATDC This equals (DURATION/2) - OPEN (provided the cam profile is symmetric.
Open 44.8 BTDC
Close 76.9 ABDC
Duration 301.8 Crank Deg. Is OPEN + CLOSE + 180 for all of the examples so far quoted.
Lash 0.0250 Inch Cold clearance (i.e. tappet clearance)
Rocker Ratio 1.00 This is always 1.00 for a direct acting valvetrain
Peak Cam Lift 0.43405 Inch Maximum lift on the cam
Peak Valve Lift 0.40905 Inch Equals max cam lift minus the cold clearance (lash)
  • 3 months later...
  David2009 said:
Found a couple of threads about this on Supraforum, it looks like the N/A inlet cam gives the T.T. another 10bhp?, with adjustable cam gears @ +1o inlet -3o exhaust giving 20bhp? more.
Very cheap add ons for BPU.
Car needs to be fine tuned and Dynoed right?!
An N/A inlet cam can be had for the asking then half a days tinkering, and the job is jobbed.
An aftermarket standalone or piggy-back ECU and a dyno tune would be best, yet I would think the stock ECU would be O.K.
This would need to be trialed, but there is some information about this to be found on Supraforum.
I used to tune Toyota deisel engines and to use an N/A inlet cam on a turbocharged engine gave a noticable gain.
