R3DG3CKO ROB Posted April 14, 2008 Share Posted April 14, 2008 Is it reccomended to have the twin electric fans on a BPU Supra? I'm currently running my N/A without the fan shroud as it doesn't fit with the Top Secret Bonnet... I'm considering getting the electric fans fitted when I have the conversion done but is it a waste of money? Real question is; does anyone run a bpu TT without the fan shroud? Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 14, 2008 Share Posted April 14, 2008 It's extremely bad practice to run without the shroud, fan efficiency will have fallen dramatically. When the weather gets hotter you may have serious problems. You may get them NOW in heavy traffic. To sell a bonnet whereby a major item of the cars cooling system has to be removed is just ludicrous. Electric fans can move nothing like the volume of air that the engine driven viscous one can, in hot conditions, they aren't in the same league. I dare not suggest the proper course of action, but I am sure you can guess.... Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 14, 2008 Author Share Posted April 14, 2008 So I have two realistic options then...? 1: Buy a modified Fan Shroud which will fit my bonnet 2: Buy the Electric Fans and risk it overheating? Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 14, 2008 Share Posted April 14, 2008 A shroud works by sealing the fan tips to stop air spilling around the edges. As far as i can see the only place a bonnet might interfere is at the top, where the only mod I can think of would un shroud the fan. Some people get by with electric fans, some suffer overheating. I'd sell the bonnet and go back to stock myself, and not risk it. I sense this may not be too appealing to you though Can't you modify the bonnet to clear? If you cut enough out of it it *may* get close to the weight of a stock one.... Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 14, 2008 Author Share Posted April 14, 2008 I've gone through such a nightmare with the bonnet now, I really wouldn't want to sell it... Why would the weight of the bonet make a difference??? Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 15, 2008 Share Posted April 15, 2008 It wouldn't, to the cooling, but i have never understood why anyone would buy an expensive carbon panel that's HEAVIER than the metal one it replaces. Seems very counter productive, cost wise. Especially when they don't even fit. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 15, 2008 Author Share Posted April 15, 2008 The bonnet weighs about half of what the original did... I carried both on my own so can def confirm that... Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 15, 2008 Share Posted April 15, 2008 Some seem to manage to weigh more than a stock one, despite being carbon fibre. You have obviously got one of the better ones, weight wise. Can't you trim whatever bit of the bonnet catches the shroud, or would that show externally as a hole then, or something? Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 15, 2008 Author Share Posted April 15, 2008 It's the structural part inside the bonnet that catches on the shroud, so probably wouldn't be advisable to start hacking into it I don't understand why someone would design a bonnet to fit a car and then it doesn't fit! I think I'm gonna have to go for the electric option and keep my fingers crossed... Link to comment Share on other sites More sharing options...
paul mac Posted April 15, 2008 Share Posted April 15, 2008 i had to do a slight mod on the shroud as my bonnet fowled it, there is quite a lot of room to trim it, i post a pic when i get home tonight Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 15, 2008 Author Share Posted April 15, 2008 cheers Paul I just want it to look as good as possible as well as being functional... Link to comment Share on other sites More sharing options...
heckler Posted April 15, 2008 Share Posted April 15, 2008 Is it reccomended to have the twin electric fans on a BPU Supra? I'm currently running my N/A without the fan shroud as it doesn't fit with the Top Secret Bonnet... I'm considering getting the electric fans fitted when I have the conversion done but is it a waste of money? Real question is; does anyone run a bpu TT without the fan shroud? TS 2 bonnet?? if so mine fits with the shroud no probs... Link to comment Share on other sites More sharing options...
paul mac Posted April 15, 2008 Share Posted April 15, 2008 here you go mate, dont know what the underside of your bonnet looks like so theres a pic of that as well, i made the cut out first then laid the piece of carbon fibre over it and drew the shape from the inside, its just epoxy'ed in Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 15, 2008 Share Posted April 15, 2008 Very neat and totally effective, I think Rob ought to plagiarise that idea Link to comment Share on other sites More sharing options...
paul mac Posted April 15, 2008 Share Posted April 15, 2008 Very neat and totally effective, I think Rob ought to plagiarise that idea chears Chris, yeah plagiarise away fella Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 16, 2008 Author Share Posted April 16, 2008 unfortunately the underside of mine looks nothing like that! Is that a custom bonnet Paul? Link to comment Share on other sites More sharing options...
paul mac Posted April 16, 2008 Share Posted April 16, 2008 unfortunately the underside of mine looks nothing like that! Is that a custom bonnet Paul? yes sorry mate, you just need to check where it fouls, little blobs of blue tack are good Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 16, 2008 Author Share Posted April 16, 2008 toothpaste works too Link to comment Share on other sites More sharing options...
Homer Posted April 16, 2008 Share Posted April 16, 2008 Rob, the Top secret one fouls on the very top doesn't it? Most have a cut a small chunk out of the top to get it to fit. Edit: You can see the very top of the shroud is cut back here: http://www.mkivsupra.net/vbb/vbpicgallery.php?do=big&p=8874 Link to comment Share on other sites More sharing options...
