imi Posted April 14, 2008 Share Posted April 14, 2008 Like New, fantastic condition and very little use. Specs and pics here. http://www.lcdsunlimited.tv/product_info.php?products_id=126 SPECIFICATIONS Display size: 19 in (48.3 cm) Display type: Active matrix TFT Viewable area: 19 in (48.3 cm) Resolution: 1280 x 1024 @ 60 Hz IMAGE QUALITY Pixel pitch: 0.294 mm Brightness (typical): 300 nits Contrast ratio (typical): 800:1 Viewing angle: 160 degrees Viewing angle (vertical): 160 degrees Response rate (typical): 5 ms (rise and fall) Frequency range (horizontal): 24 - 83 kHz Frequency range (vertical): 50 - 77 Hz Signal input: Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D Ports: Rear - 2 USB 2.0 Impressive spec. £100 ono Link to comment Share on other sites More sharing options...
imi Posted April 19, 2008 Author Share Posted April 19, 2008 bump Link to comment Share on other sites More sharing options...
imi Posted April 23, 2008 Author Share Posted April 23, 2008 Revised... Link to comment Share on other sites More sharing options...
imi Posted April 30, 2008 Author Share Posted April 30, 2008 bttt Link to comment Share on other sites More sharing options...
