Auto Gear Lever Lights
damientt
Duhhhhhh - subject should have read "Auto Gear Lever Lights"
The lights beside/below my gear lever (the gear selector indicator lights - R, D, etc.) seem to have gone out. Everything else appears to be OK so I assume it's not a blown fuse. I removed the plastic gear lever surround but couldn't see any obvious bulbs to replace and I didn't want to start taking anything else out.
Any ideas???????????
Thanks for the help. I replaced the original blown bulb with a blue LED so it now matches my blue dash conversion :) :)
A bit of advice. I used a small spanner (8mm?) to remove & re-mount the bulb holder ... makes it a bit easier.
