Urgent Help - Compression Test Number, are they OK?
Kim1978
I am looking into buying a bpu+ TT 6-speed with 43.000 miles on the clock. The car was throughly checked by a Toyota technician.
There were some issues
* small/slow leak from the transmission
* tyres are done
* low idle/occasionally stalls
* car is lowered and the exhaust is scraped/smashed
* engine/clutch vibration since a RPS stage 3 race clutch has been installed. I was told that was perfectly normal
* alignment needed
* small ding on front right fender
That really didn't worried me that much, what REALLY worried me was the compression test
#1 135
#2 115
#3 135
#4 125
#5 115
#6 130
First I think the numbers are very low, second, the difference between 1st and 2nd cylinder is about 17%. I was under the impression 5% is great, 10% is OK but shouldnt be higher than that.
I talked to the technician who said the numbers were low but he wasn't worried about them. He told me the numbers are on the borderline what is acceptable but he believed the main reason for being low are the aftermarket adjustable cam gears (set very aggressively) from Titan. He was also very certain those were the reason why the car idle very low and stalls now and then.
What should I do? The seller is letting it go for below market since he is aware of some of these defects but the compression numbers were a major surprise for him too. I would also like to point out, the seller seems very honest and he even paid for this whole car-check even though it was done for me.
Sorry but the compression discrepancy figures are not good, and the bit about the cam gears causing it is bull, possibly would cause then all to be low or high but would not account for the difference in cylinders, and unless it has high overlap/lift cams then the gears would not account for the bad idle alone.
You could always reset the cam gears and recheck the compression.
Clutch wise, if its a twin or triple plate then you will get some noise/rattle but it should not cause vibration once engaged, and if its single plate then no other than the usual gatrag clunk.
  • 2 weeks later...
