Mcgoo Posted April 11, 2008 Share Posted April 11, 2008 Can anyone thats changed a SMIC please tell me roughly how long it will take? I'm in a bit of a dilema. I was gonna change mine today before tomorrows event at Marham as mine is shot but the replacement nuts, bolts and bumper fixings I ordered haven't been delivered. I just spoke to the post office and they said they could be in the delivery van but couldn't say for sure. If they were they would arrive between 1pm and 3pm. So, do I start the job now and hope they arrive this afternoon so i can finish it off? There is a risk of them not arriving and if things break when removing the bumper I could be without the car tomorrow. Or, do I wait and see if they turn up and only start the job once I've got them? If they don't I will have to run with a shot intercooler which is not good. If they do turn up will I have time to do the job without working late into the night? What do you reckon ? Link to comment Share on other sites More sharing options...
Mcgoo Posted April 11, 2008 Author Share Posted April 11, 2008 Oh yeah, and does the active spoiler get in the way of bumper removal ? Cheers, Link to comment Share on other sites More sharing options...
JohnA Posted April 11, 2008 Share Posted April 11, 2008 It depends how quickly you can take off the front bumper and put it back. The SMIC can be swapped with the bumper in place (I've done it) but it is fiddly. Link to comment Share on other sites More sharing options...
Mcgoo Posted April 11, 2008 Author Share Posted April 11, 2008 It depends how quickly you can take off the front bumper and put it back. The SMIC can be swapped with the bumper in place (I've done it) but it is fiddly. Thanks for the reply. Its a larger Trust SMIC do you think it could be done without removing the bumper still? Do you do it through the wheel arch ? Link to comment Share on other sites More sharing options...
michel lane Posted April 11, 2008 Share Posted April 11, 2008 its easy to replace, you wont have to take the bumper off, what you need to do is : 1:Take the drivers side light off 2:Take your driverside wheel off 3: Remove the plastic cover in the inner arch , just behind the smic and remove the plastic over underneath the smic 4: then you got the SMIC fully exposed 5: The most difficult part is removing the bolt from the front of the smic that attches it to the side of the main subframe. But with the correct tools it should not be a problem. use plenty of WD40. total time i would say 2 hours if you going slow . good luck. make sure you wipe the hoses with degreaser before re-attaching them and if the jubliee clips look abit worn , change them, even put 2 clips on each connection to garrentee it not poping off as its a chew to get them back on when they pop off. good luck Link to comment Share on other sites More sharing options...
Mcgoo Posted April 11, 2008 Author Share Posted April 11, 2008 its easy to replace, you wont have to take the bumper off, what you need to do is : 1:Take the drivers side light off 2:Take your driverside wheel off 3: Remove the plastic cover in the inner arch , just behind the smic and remove the plastic over underneath the smic 4: then you got the SMIC fully exposed 5: The most difficult part is removing the bolt from the front of the smic that attches it to the side of the main subframe. But with the correct tools it should not be a problem. use plenty of WD40. total time i would say 2 hours if you going slow . good luck. make sure you wipe the hoses with degreaser before re-attaching them and if the jubliee clips look abit worn , change them, even put 2 clips on each connection to garrentee it not poping off as its a chew to get them back on when they pop off. good luck Thanks Michel, I'll have a go now. See you at Marham. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 11, 2008 Share Posted April 11, 2008 Work late into the night, that way you become a PROPER racer Link to comment Share on other sites More sharing options...
ManwithSupra Posted April 11, 2008 Share Posted April 11, 2008 Took me a couple of hours but then i did have my mother in law talking at me while i was balancing the SMIC with one hand and trying to get the bottom pipe in the other while sitting in the sun with the sun in my eyes. Link to comment Share on other sites More sharing options...
Suprash Posted April 11, 2008 Share Posted April 11, 2008 Work late into the night, that way you become a PROPER racer Ha, ha, nice one Chris....... Link to comment Share on other sites More sharing options...
Mcgoo Posted April 11, 2008 Author Share Posted April 11, 2008 Work late into the night, that way you become a PROPER racer Link to comment Share on other sites More sharing options...
Pixelfill Posted April 11, 2008 Share Posted April 11, 2008 Is that a grin or a grimace? Did the SMIC turn up? The suspense is killing me Mike Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 11, 2008 Share Posted April 11, 2008 Sshhhh, he's working late into the night.... He'll nail your hats on tomorrow! Link to comment Share on other sites More sharing options...
