Need4Speed Posted July 29, 2002 Share Posted July 29, 2002 I have a turbo timer by Starbo. It has four push buttons on the front labelled "off, 1, 3, 5". I assumed they were minutes of running time. The timer was not connected when I bought the car but I've plugged it back in and it works only it NEVER switches off the engine. There's a white wire coming out of the unit which has been cut off. I expect this is an obscure Japanese unit but has anyone ever met one and got it to work (you could save me £100 which is worth a beer or two)? Quote Link to comment Share on other sites More sharing options...
Rob_B Posted August 2, 2002 Share Posted August 2, 2002 I take it you can't see where the white wire was connected to before it was cut off ?? Rggds, Rob. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 2, 2002 Share Posted August 2, 2002 It may need programming to tell it how long to run for - That's not much help though. I don't suppose you have a Clifford alarm fitted? - You can make one of the channels become a timer quite easily. Sorry, not much help am I Quote Link to comment Share on other sites More sharing options...
