brians25 Posted April 9, 2008 Share Posted April 9, 2008 is it possible for the auto box to slip as when i hit the kickdown the engine revs rise by about 2k but the car doesn't get any faster for about 2 secs or so an then off it goes .its almost the same feeling as you get when the clutch is starting to slip in a manual Link to comment Share on other sites More sharing options...
tDR Posted April 9, 2008 Share Posted April 9, 2008 Yes the clutch bands wear and you can get slip. Have you checked your autobox fluid level? When's the last time it was changed - if it looks brown and smells burnt it's probably too late for your box. The good news is that 2nd hand autoboxes go on here for around £250 so won't exactly break the bank! Cheers, Brian. Link to comment Share on other sites More sharing options...
RedM Posted April 9, 2008 Share Posted April 9, 2008 is it possible for the auto box to slip as when i hit the kickdown the engine revs rise by about 2k but the car doesn't get any faster for about 2 secs or so an then off it goes .its almost the same feeling as you get when the clutch is starting to slip in a manual Absolutely. I had this and despite people saying it was the VSV's and other nonsense it did turn out to be the box. A refurbed box sorted the problem. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted April 9, 2008 Share Posted April 9, 2008 Mine makes a slight whistle sound in 1st before dropping into 2nd , not sure what this can be but its annoying . Link to comment Share on other sites More sharing options...
brians25 Posted April 9, 2008 Author Share Posted April 9, 2008 i'll do an oil change on the box an see if it helps, if it comes to it i'll ditch the auto an source myself a manual box from somewhere, thanks for the replies guys Link to comment Share on other sites More sharing options...
jamesmark Posted April 9, 2008 Share Posted April 9, 2008 if it comes to it i'll ditch the auto an source myself a manual box from somewhere, It is not as simple as that I am afraid, to go manual it will set you back at least £2k-£2.5k. Thats after you beat eaveryone to buying one as they are very desireable. Link to comment Share on other sites More sharing options...
GoliathJay Posted April 9, 2008 Share Posted April 9, 2008 Fill the box with wood shavings, works a charm! Link to comment Share on other sites More sharing options...
AgtX80 Posted April 10, 2008 Share Posted April 10, 2008 £250 for the box but how much on top for the fitting of it? wood shavings? Link to comment Share on other sites More sharing options...
Andyhannah Posted April 10, 2008 Share Posted April 10, 2008 We will fit a new box for £320 including fluids. I also have a gearbox Andy Link to comment Share on other sites More sharing options...
GoliathJay Posted April 10, 2008 Share Posted April 10, 2008 £250 for the box but how much on top for the fitting of it? wood shavings? A lot of american dealerships used to fill slipping boxes with woodshaving so on test drives they would work, but not for long! Link to comment Share on other sites More sharing options...
brians25 Posted April 10, 2008 Author Share Posted April 10, 2008 well i am gonna try the fluid change first an then if it comes to it or the problem becomes worse then i may take the box apart myself(i am heavy plant engineer to trade) have done a few earthmover autoboxes so how hard can a supra be.... the ones i normally do have 16 fwd an 16 rev gears Link to comment Share on other sites More sharing options...
AgtX80 Posted April 10, 2008 Share Posted April 10, 2008 i have similar symptoms, the car was serviced before i bought it, the fluid is pink, maybe the stuff they drained out was the stinky burnt stuff. It doesnt always slip so i will put up with it for a bit. Link to comment Share on other sites More sharing options...
brians25 Posted April 11, 2008 Author Share Posted April 11, 2008 just another note: doesn't do it whilst in manu mode, Link to comment Share on other sites More sharing options...
